best way to mold?
huber
Member - Posts: 39
Posted: June 19, 2007 at 7:25 PM / IP Logged
I am curious.....What is the best way to recreate with fiberglass.....For example if I wanted to take a gauge pod and make a new one.....How could I recreate that????
huber
Member - Posts: 39
Posted: June 20, 2007 at 8:32 AM / IP Logged
No ideas???
isa-kuruption
Member - Posts: 18
Posted: June 20, 2007 at 9:08 AM / IP Logged
huber wrote:
No ideas???
Check out JL Audio's website for their tutorials... one of them explains how to mould a subwoofer box, which you may be able to use in your particular case.
jlord16
Silver - Posts: 322
Posted: June 20, 2007 at 9:56 PM / IP Logged
I recently made a guage pod from a master mould.
Easiest way is to mask up the pod and fibreglass over the top of it.  Once the glass is dry remove it and the tape,  Then do a skimcoat of bodyfiller and a light sand and its all done.  I will try find some pics if you like
Clarion DB36MP
Infinity Kappa Perfect 10"
Respone 800w Mono
ALPINE MRP-F250
*Custom fabrications*
bellsracer
Silver - Posts: 703
Posted: June 20, 2007 at 10:05 PM / IP Logged
For more complex shapes look into algenate molding material... a bit pricey but produes a BEAUTIFULLY detailed recreation of whatever and reusable. Since it is "soft" you can also put imprints that are 3-D into it as well.
Also there is a plaster available too (the name and number escape me at the moment but I'll post asap)
Ganbatte ne!
huber
Member - Posts: 39
Posted: June 20, 2007 at 10:28 PM / IP Logged
Thanks guys......I kinda thought that is what I would need to do....tape and fiberglass over it...
