hid 07 dodge ram
07dodgeram
Posted: May 21, 2008 at 7:12 AM / IP Logged
I recently bought a conversion kit for HID for my 07 dodge ram.  Everything is hooked up by the directions, but I have a problem.  When the truck is not running the lights work but as soon as I turn on the engine the lights go out.  Is there any wisdom someone could share on this matter?  I saw similar posts about everyone else having flickering, I don't have flickering, they just shut off.  Thanks, Josh
Platinum - Posts: 12,488
Posted: May 21, 2008 at 8:27 AM / IP Logged
Is this a plug and play system or is it a hard wired system ?
07dodgeram
Posted: May 21, 2008 at 9:20 AM / IP Logged
Yes it is supposed to be a plug and play made by OLLO, I got it off of ebay.  I have been messing around with a couple different things.  I tried a capacitor that some tech guy told me to try, didn't work.  Any suggestions?
07dodgeram
Posted: May 21, 2008 at 1:28 PM / IP Logged
*update*  I got them working.  I just beefed up the wire gauge and put in 2 relays instead of 1.
night runner
Posted: August 09, 2008 at 7:52 AM / IP Logged
I have a 06 Ram with the same proble.  I ordered 2 new relays and the company  that makes the HID kit sent me two seperate relays and harnesses attached to them.  I tried the 2 new relay I bought and they solve the problem but the lights will not shut off.  I tried the harness/relay kit that HALO sent me and I lose the high beams.  Can you tell me what you did to make them work.  Did you keep the original relay and add  1 more or did you replace the original with your own.   I used the momentary to constant diagram in the relay section to see if that would solve it but just ended up wasting alot of connections for the same overall result.
Thanks,
Josh
