temperature displays
bigjohnny
Copper - Posts: 293
Posted: March 17, 2009 at 7:23 AM / IP Logged
Im not sure if this is the right place to put this, but this seems like the "electronics" section, sorry if its in the wrong place.
Are there any circuits available that will read and display temps for certain probes on an LCD screen, perhaps something a little nicer than a basic clock looking screen.
I want to put a couple of temp probes in my trunk to keep track of temps, but I don't know how I would display it.
I also want to be able to control a device if the temps get too low (a heater).
Does anything like this exist? could I build one? (yes I could BUILD one.... design one, no)
KPierson
Platinum - Posts: 3,527
Posted: March 17, 2009 at 8:50 AM / IP Logged
Dakota Digital has some temperature probes / displays.  If you can get the probe and display installed I wouldn't think it would take too much to trigger a relay if the temp gets too low.
I looked in to doing something like this years ago but never went through with it.  I was going to use a simple RTD and a 2x20 display.
Kevin Pierson
bigjohnny
Copper - Posts: 293
Posted: March 17, 2009 at 5:53 PM / IP Logged
This is something I want to look into, our winters are cold, and I want to mount a little heater in my trunk so I can keep an eye on temps in there (humidity would be the icing). I dont want to fire up my system when its been sitting overnight in -25C weather.
If I had a heater in there, it could be turned on to get the temps in the trunk up to something a little more acceptable.
I was also considering using a peltier to keep my amps cool(either directly on the heatsinks, or making a chiller of sorts like those electric coolers) but I just don't think thats an option... not one worth doing anyway....... gonna have to just go with a ton of fans :D
KPierson
Posted: March 18, 2009 at 5:53 AM / IP Logged
What about a heater with a built in thermostat?  You could power it off the ignition and possibly even set up a "low temp" light off of it.
Kevin Pierson
bigjohnny
Copper - Posts: 293
Posted: March 18, 2009 at 6:48 AM / IP Logged
thats not a bad idea, but I would still like to see what the actual temps are.
I'm a very visual person, and I like to be in control of my machines.
What I'm looking for I guess is some form of temperature controller.
I see an ad above for custom electronic design.... I wonder if they can design something for me..... more importantly, what would it cost lol.
KPierson
Posted: March 18, 2009 at 12:30 PM / IP Logged
They make all types of temperature controllers and displays - places like www.omega.com would be a good start.   These are more industrial devices though, so you'll need to make sure they'll work down to 12vdc.
Kevin Pierson
bigjohnny
Copper - Posts: 293
Posted: March 19, 2009 at 5:01 PM / IP Logged
I'm kind of lost there, I'm not entirely sure what it is that I'm looking for, so it makes it a little hard to find there.
Also from what I've seen of their controllers/displays, they are the big blocky ugly LCD displays..... I want to make my car look like its from the future, not back to the future ;)
...... although I do need more jigawatts......1.21 of them.
bigjohnny
Copper - Posts: 293
Posted: March 26, 2009 at 6:49 AM / IP Logged
I've found this, http://www.geocities.com/ CapeCanaveral/Launchpad /3632/scriptherm/scriptherm.htm It might work, But I can't exactly follow the diagram, its a little bit beyond me ..... on top of that, the biggest problem is where would i get a PCB for this?
bigjohnny
Copper - Posts: 293
Posted: March 26, 2009 at 10:04 PM / IP Logged
ok, here is a slightly better one, or more ready to go anyway.
http://..ca/Digital-Thermometer -Temperature-Meter -Gauge-C-F-PC-MOD _W0QQitemZ250396214426Q QcmdZViewItemQQptZ Weather_Devices? hash= item250396214426 &_trksid= p4634.c0 .m14.l1262
But would there be some way to tap into it to activate a heater when the temp is below 10C?
KPierson
Posted: March 26, 2009 at 10:11 PM / IP Logged
For the price it's worth a try.  I would say it is safe to assume the signal coming back on the probe is a voltage, so I would think it could be modified to work with other applications.
Kevin Pierson
Page of 9
