Running Board LEDs Fade In/Out with Dome Lights
cam english
Posted: August 01, 2018 at 9:50 PM / IP Logged Link to Post Post Reply Quote cam english
I have a 2017 silverado and have done some research so i do know which wire i need to tap into for my dome lights but i want to run four led rock lights on my running boards that fade in and also fade out with my dome lights. I will be using four of these rock lights Click Here Wouldn't i need a relay controlled by my dome lights because of the amps they will pull? If so how could i wire it for it to fade? This maybe a dumb question. Thanks in advance
eguru
Copper - Posts: 340
Posted: August 02, 2018 at 8:51 AM / IP Logged Link to Post Post Reply Quote eguru
So, you only want the running board lights to be on when the dome light is on and you want them to fade out in-synch with the dome lights?
If so, and although you didn't specify which model you are going to use, you should be ok to connect directly to the dome light feed wire.
The current draw should be less than 2 amps.
cam english
Posted: August 02, 2018 at 9:02 AM / IP Logged Link to Post Post Reply Quote cam english
I think I’m going to go with the white high output model. Would I be ok with the original fuse that is on the dome lights or do I need to change somthing?
eguru
Copper - Posts: 340
Posted: August 02, 2018 at 10:31 AM / IP Logged Link to Post Post Reply Quote eguru
Original fuse should be fine. Never increase the size of the fuse.
cam english
Posted: August 02, 2018 at 10:35 AM / IP Logged Link to Post Post Reply Quote cam english
Thanks a ton bud
Tuesday, May 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
