headlights APC how to plug?
Pascal
Member - Posts: 7
Posted: January 22, 2005 at 5:50 PM / IP Logged
j ai changé mes headlights d origine pour des headlights APC, j ai trois fils sur la plug de mes lumieres d origine (1 petit rouge, 1 gros rouge et 1 noir) . Maintenant je dois brancher ca sur deux ampoules, (APC sont tellement ''colon'' qu il n ont pas mi des plug comme sur les headlight d origine)
es ce que quelqu un sait comment brancher ces 3 fils sur les deux ampoules?? ai-je besoin de relays? il y avait quoi dans les headlights d origine??
merci de votre aide
Platinum - Posts: 12,488
Posted: January 22, 2005 at 6:04 PM / IP Logged
English Please
Pascal
Member - Posts: 7
Posted: January 24, 2005 at 1:03 PM / IP Logged
Velocity Motors wrote:
English Please
I buying headlights APC. I have 3 wires on the original plug of the car (1 small red wire, 1 big red wire and 1 black wire. Now, I have 2 bulb in my headlight.
Everyone know how plug it??
thanks
Pascal
Member - Posts: 7
Posted: January 30, 2005 at 10:31 AM / IP Logged
English Please
thanks
EVERYBODY KNOW?
Pascal
Member - Posts: 7
Posted: February 11, 2005 at 10:43 PM / IP Logged
Pascal wrote:
English Please
thanks
EVERYBODY KNOW?
everyone have an idea ?
geepherder
Platinum - Posts: 3,668
Posted: February 14, 2005 at 9:35 PM / IP Logged
I hope you're not planning on driving at night with these APC lights.  The optics on them are terrible, much worse than OEM even.
You didn't say what car this is.  Grab your multimeter and begin taking readings.  The center pin on your bulb should be common.  Try reading resistance from the center pin to each of the outside pins.  The filament with the lower resistance reading is for your high beams.
geepherder
