Replacing instrument cluster bulbs
Texas Dodge
Member - Posts: 6
Posted: February 01, 2006 at 12:34 PM / IP Logged
I plan on replacing all 11 of the instrument cluster incadescent bulbs with blue leds. Will I need to install resistors for them or can I just remove the old bulb from the plastic twist and lock base, installing the led and reinstall the base back in the cluster? The leds are 12 volts and are 18~22 ma.
Thanks for any help.
ingolf
Member - Posts: 21
Posted: February 01, 2006 at 9:31 PM / IP Logged
you will need a current limiting resistor.
otherwise your led's life will shorten alot.
use an led resistance calculator
blazinred99
Member - Posts: 12
Posted: February 02, 2006 at 8:24 AM / IP Logged
http://www.superbrightleds.com/mini-wedge.html
If your cluster uses the 194 or the 168 bulb buy some of these.  they have resistors in them already so you won't need resistors.
Texas Dodge
Member - Posts: 6
Posted: February 02, 2006 at 9:28 AM / IP Logged
My truck has #74's in it. I am replacing them with these from discountleds.com
haemphyst
Platinum - Posts: 5,059
Posted: February 02, 2006 at 10:25 AM / IP Logged
You wont need current limiters... already in place with those items...
Texas Dodge
Member - Posts: 6
Posted: February 02, 2006 at 10:38 AM / IP Logged
Thank you very much. Good news to hear.Replacing instrument cluster bulbs -- posted image.
