Converting driving lights to ddl's
2kflhr
Posted: February 20, 2006 at 11:15 AM / IP Logged
My son just got a '91 Camaro RS for his 16th b-day. I installed the IROC grille and have a set of OEM driving lights. Being he is a new driver and his car being a darker blue and harder to see at times, I was thinking that I would wire the driving lights to operate like daytime driving lights.
If I tap off of a terminal in the fuse block that energizes with the ign. sw. would I need a relay to help with the current draw?
I was planning on using a switch to kill the power to the lights if necessary.
All suggestions and recomendations are highly appreciated.
Good Judgement is gained from experience, some experience is gained from Bad Judgement
dlek
Member - Posts: 26
Posted: March 15, 2006 at 2:53 PM / IP Logged
I would reccomend using a relay simply because they are inexpensive, and it is better to play it safe. By using a relay you will not disrupt any fuses or other electrical mechanisms.
and by the way cool car!
