multiple ground wires
ermac
Posted: April 02, 2007 at 5:24 PM / IP Logged
Real simple and quick for the right person.
I am installing new lights on a Dodge Ram 1500 5.9L V8 with a 24DL 12V Batt.
Off the light kit comes a +positive and -negative set of wires, ok, easy.
I have a toggle switch for the inside of the truck.
The toggle has POWER - LOAD - GROUND
Ground of corse going to a peice of metal on the truck, POWER being the positive from the bat to the switch and from switch to lights,
and LOAD is one issue, I was told take the Negative wire from the lights, and ground them to the truck, and leave the LOAD prong on the toggle switch alone?
and 2nd, am I able to ground these wires to the same ground point to where which the battery is also grounded. Called Autozone, they said no.
Mad Scientists
Silver - Posts: 380
Posted: April 02, 2007 at 5:53 PM / IP Logged
On the toggle switch; (it sounds like the toggle switch has three connections, and is a lighted switch)
load - the lights
ground - ground
power - 12+
ermac
Posted: April 02, 2007 at 5:56 PM / IP Logged
so... you mean this.
Power - runs from bat to power on toggle
ground... duh..
load... runs from positive wire on lights to load on toggle switch.
then the negative on the lights should be grounded? and can you ground multiple wires to one point?
I grounded that ground wire from toggle to same grounding point as the ground for the battery.
ermac
Posted: April 02, 2007 at 6:42 PM / IP Logged
more simple... lol
TOGGLE SWITCH w/ 3 Prong INC LED
POWER: Wire from 12v battery to POWER prong
LOAD: Wire from POSITIVE of lights to LOAD prong
GROUND: wire from metal to GROUND prong
Questions:
What do you do with NEGATIVE from lights? put on metal as ground like autozone said?
Can you ground multiple ground wires to same ground point?
Mad Scientists
Silver - Posts: 380
Posted: April 03, 2007 at 6:36 AM / IP Logged
Use fusing, but that sounds right.. ground the negative wire off the lights. I'm not sure what you're talking about WRT multiple wires, but as long as the connections are good, there isn't any problem in connecting more than one ground wire to any one point.
Jim
