amp problems rca's maybe?
badasschevillac
Member - Posts: 32
Posted: June 06, 2008 at 6:52 PM / IP Logged
have a ma audio hk-4000d powering a 18" fi loaded BTL previously had it in an s-10 worked perfect took it out cuz i sold truck kept in my house for about 3 weeks put in my other truck hooked it up the same way and nothing!
power is good
ground is good
remote turn-on is good
tried 4 different kinds of rca's on my current head-unit which previously had subs hooked to it and they worked fine
tried a whole different head unit nothing
could it be burnt or bad rca terminals on the amp? or what
any help is greatly appreciated!!! thanks
Platinum - Posts: 13,694
Posted: June 06, 2008 at 6:59 PM / IP Logged
Did you use a volt meter to determine that power ground and remote were good?
badasschevillac
Member - Posts: 32
Posted: June 06, 2008 at 7:20 PM / IP Logged
yes
Posted: June 06, 2008 at 9:12 PM / IP Logged
Read the other thread and check your RCA cables with the meter to see if there is any voltage present on the cable.
Sunday, November 10, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
