alpine 9886 and hard drive through usb
00sonoma
Member - Posts: 39
Posted: November 11, 2008 at 8:42 PM / IP Logged
Looking for info on connecting a hard drive to the USB port on my alpine 9886
Platinum - Posts: 13,726
Posted: November 11, 2008 at 9:18 PM / IP Logged
As far as I know, they will play only Jump drives.
Hornshockey
Silver - Posts: 520
Posted: November 12, 2008 at 12:32 PM / IP Logged
From what the specs say, as long as it is formatted in FAT 16/32 and doesn't draw more that 500mA through the USB, there's no reason it shouldn't work.
I think the power consumption is gonna be your problem, you'd have to use a hard drive with a separate power supply, and that means using an inverter.
Life moves pretty fast; if you don't stop and look around once in a while; you could miss it.
lspker
Silver - Posts: 503
Posted: November 12, 2008 at 9:52 PM / IP Logged
Denision make a 2to1 USB adapter that powers up to 1 amp.
00sonoma
Member - Posts: 39
Posted: November 12, 2008 at 10:07 PM / IP Logged
ok so what all would I need, I have a few laptop and desktop hard drives here, how would I format it? Does it still need windows installed? Would an external hard drive housing work
Posted: November 13, 2008 at 6:12 AM / IP Logged
That would help out a lot, if of course there were 2 USB ports on his radio.
00sonoma
Member - Posts: 39
Posted: November 13, 2008 at 1:28 PM / IP Logged
Ok is the pink audio int. In wire a -or + input.
I wanna use a wire from my remote start to keep it from bumping
Posted: November 13, 2008 at 2:44 PM / IP Logged
Mute is negative.   According to Alpine's tech suppport, that unit will play a hard drive.  It must be a single platter drive.  New large laptop drives, (250 and 300 GB) use multiple platters.   It as stated above needs to be formatted with FAT or FAT32 partitions.
daburrrninator
Member - Posts: 31
Posted: November 13, 2008 at 5:29 PM / IP Logged
Try one of the USB powered laptop externals. I have the 120gb version of this drive http://www.bestbuy.com/site/olspage.jsp?skuId=8744736&st=western+digital+external&type=product&id=1202648989707 hooked up to my Pioneer. Works great. Those are meant to draw only 5oomah.
00sonoma
Member - Posts: 39
Posted: November 13, 2008 at 6:56 PM / IP Logged
that sounds like what I am looking for . I would rather have a hd instead of my iPod in there
Thursday, May 21, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
