hooking up crossover
dred
Copper - Posts: 158
Posted: April 15, 2009 at 12:09 PM / IP Logged
hey guys i want to buy an crossover the "Lanzar VIBESX7". I have a pioneer deh-p5000UB head unit with front,rear and sub outputs. I was wondering how cud i fit the crossover into my system with the crossover having 2 INPUT RCA jack and 6 channel outputs, How should connect this to work with my Clarion EQS 746 EQ. I  cant see how they could be connected helpppppp meee plz guys
dre
DYohn
Moderator - Posts: 10,741
Posted: April 15, 2009 at 1:58 PM / IP Logged
It can be hooked up several ways.  How do you plan to use it?
dred
Copper - Posts: 158
Posted: April 15, 2009 at 3:02 PM / IP Logged
ok i want to use the eq and the crossover  but i dont know how to hook it up. Just tell the ways which u think is best thanks.
dre
DYohn
Posted: April 15, 2009 at 3:20 PM / IP Logged
Like I said, what do you want to use the crossover FOR?  What do you hope to accomplish with it?  What else is it hooking up to?
dred
Copper - Posts: 158
Posted: April 15, 2009 at 4:14 PM / IP Logged
well i will be hooking it up to a 4 channel XS 880 watt amp just for mids and highs
dre
DYohn
Posted: April 15, 2009 at 5:20 PM / IP Logged
OK, so I recommend installing it after your EQ.  Connect the EQ to the front RCA outputs from your head unit, then connect the RCA outputs from your EQ to the input on the crossover and use the high and mid outs from the crossover to the appropriate amplifier channels.  Then commence your setup.
dred
Copper - Posts: 158
Posted: April 15, 2009 at 7:08 PM / IP Logged
ok thanks for the reply but this crossover only has 2 RCA input how to connect it " i wanna buy this "Lanzar VIBESX7" crossover its a dash crossover.
dre
Platinum - Posts: 13,693
Posted: April 15, 2009 at 7:22 PM / IP Logged
Does it have a Front and Rear input, or is it Front and Subwoofer?
Have you heard of Pyramid Car audio equipment from 20 years ago?
DYohn
Posted: April 15, 2009 at 9:58 PM / IP Logged
Lanzar used to be good stuff, but man that thing looks like a piece of crap to me... regardless, I suggest if you purchase it, read the owner's manual and follow the instructions.  If it only has one set of RCA inputs then use it  with the front channels of your HU.
Posted: April 15, 2009 at 10:00 PM / IP Logged
It looks like that because it is a Pyramid piece.  They bought the name when Lanzar went belly up.
