what is the smallest 2 channel amp?
digdug18
Member - Posts: 23
Posted: February 16, 2010 at 9:04 PM / IP Logged
I searched and couldn't find anything, for mini, small, or micro amps.
What is the smallest amp? I found the arc audio xxd-2080, its 6 1/2" (L) x 7 1/8" (W) x 1 7/8" (H), but is there something in a smaller footprint?
Andrew
licto
Member - Posts: 42
Posted: February 17, 2010 at 6:57 PM / IP Logged
I think we all get the jist of what you are asking......  however most people on this forum like to have some details.....
What is the project, vehicle, any other components.....  ect.....
When you say small, are you talking about electrical.....  as in watts, or external enclosure dimensions of the amp.....
Details motivate everyone here.....
donrico
Posted: February 18, 2010 at 1:11 AM / IP Logged
gat a question to add to that ...  what the most watts on a amp that i could put on factory  mids and highs???? like would anyone recomend puttin a 800 watt full range 2 channel amp on factory car speakers puttin the amp on high pass filter?
DBrennen
oldspark
Gold - Posts: 4,913
Posted: February 18, 2010 at 2:45 AM / IP Logged
Yep - no problem - provided the factory mid/high speakers are 400W per channel.
donrico
Posted: February 18, 2010 at 10:41 AM / IP Logged
can i put tweeters on that same amp?? if so, how is that possible or how can i do it becus i cant think of a possible neat connection way
DBrennen
haemphyst
Platinum - Posts: 5,059
Posted: February 18, 2010 at 1:31 PM / IP Logged
Not necessary at all to match the power rating of the amplifier to the speakers. It IS necessary to match the output of the amplifier to the power rating, using the "level matching stage", i.e. "gain control".
I have over 1300 watts RMS running my doors... 330 to the woofers (each) and 175 to each mid and tweeter. All those drivers combined equal a total power rating of under 600W.
oldspark
Gold - Posts: 4,913
Posted: February 18, 2010 at 6:20 PM / IP Logged
Ah - the advantages of modtech. In ye olde bad days you'd have to add resistive ladders, else limit the rotation of the the loud dial. (Some would merely erase the higher numbers, but eventually some joker would turn it past its highest setting/number).
Thanks H for modernising me yet again.
donrico
Posted: February 18, 2010 at 6:25 PM / IP Logged
so wat u guys sayng is that i can put a high amount of watts on my FACTORY mids/highs/ and a set of tweeters that i prob wud have to buy  but i wud have to turn my settings down on the amp. but if i turn the settin  down for those in door speakers , lets say to like low pass filter  with sum low frequence or sumthing then that means i cant use that same amp to push my subs becus i have the setting on my amp for the mid/highs/and tweetes.....? i wud need a 2nd amp for my subs.. correct?
DBrennen
spmpdr
Copper - Posts: 456
Posted: February 21, 2010 at 3:34 PM / IP Logged
I think it was pretty clear that he was talking about the footprint of the amp ,because of the dimensions and the question at the end in wich he asks for recommendations of amps with small footprints... just my 2 cents though!!!Anyone else not understand his question?
-A vision without a plan is just a hallucination-
digdug18
Member - Posts: 23
Posted: March 06, 2010 at 12:23 AM / IP Logged
I'm talking about the actual dimensions of the amp, the footprint, as stated. And wth, why do people threadjack, why not start your own thread if you have a question.
As for the vehicle, its a 2004 saturn vue, i'm adding an amp, or trying to under the front drivers seat, there really isn't any room anywhere else. I'm using the factory headunit, its a double din dvd player, that plays disks on the roof mounted tv. When the dvd player is sending the audio to the tv, it uses the rear speakers only, the front speakers can be then tuned to a radio station and both the front and rear passengers can listen to different things.
I found the Arc Audio mini series of amp's, they have a 2 x 70 watt that's dimensions are 8.25(L) x 4.8” (W) x 1.7”(H). Is that the smallest amp I will find that is of a good quality?
Andrew
Monday, March 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
