hooking up highs amp
pitdawg47
Copper - Posts: 72
Posted: March 20, 2010 at 8:31 PM / IP Logged
Ok i really need help hooking my highs up right..
heres my amp im useing   http://soundtoyzaudio.com/index.php?act=viewProd&productid=353
FRONT
alpine componets  (6" and tweeter)
REAR
orion colbalt 6x9s SAYS there 3ohms
and have pair of massive tweeters
the 3 ohm 6x9s are thowing me off..
 I was going to hook front alpines comp.. to channel 1 and 2  stright + to +  and - to -        and twist the 6x9 and tweeter wires toghter  and run them stright + to + and - to - AND put them ---> 1 6x9 and 1 tweeter on channel 3 and 1 6x9 and 1 tweeter on channel 4 ... is this right or im i way off...   please help is there a better way to hook all this up?
nodiggie
Copper - Posts: 69
Posted: March 20, 2010 at 11:40 PM / IP Logged
looks like you are good up till u get to the 6x9 and tweeters. If you run the 6x9 and tweeter in SERIES, you will be ok. Correct me if I'm wrong (somone) but assuming the tweeter that is to powered together with the 6x9 is 4ohm, it would need to be ran in series for 7ohm load. If ran in parallel it would be 1.71ohm?
According to the amp's spec. it is only stable down to 2ohm stereo.
Still learning
Kraco
pitdawg47
Copper - Posts: 72
Posted: March 21, 2010 at 12:17 AM / IP Logged
how do i run them in series?
pitdawg47
Copper - Posts: 72
Posted: March 21, 2010 at 12:24 AM / IP Logged
ok  so yea fronts all good.. now for rear .. rember 6x9s are 3ohm  and nto sure what ohm massive tweeters are...   would i need anthor amp to run tweeters? i would think throwing  tehm on the 6x9 channels wouldnt make much diffrence .. but thats why im here asking someone that knows... what yall think?
nodiggie
Copper - Posts: 69
Posted: March 21, 2010 at 12:49 AM / IP Logged
6x9 + >  - on tweeter + of tweeter > amp - of 6x9 > amp.
Make sure the tweeter has a capacitor, if not and you run full range out to it... POOOF! Time for a new tweeter.
Still learning
Kraco
pitdawg47
Copper - Posts: 72
Posted: March 21, 2010 at 11:55 AM / IP Logged
i think i need a drawing.. im not getting the picture.. ??
nodiggie
Copper - Posts: 69
Posted: March 21, 2010 at 3:48 PM / IP Logged
hooking up highs amp -- posted image.
Don't concern yourself with the ohms on this drawing. This is how you hook two speakers in series.
Still learning
Kraco
Tuesday, May 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
