mounting sub box to frame?
pitdawg47
Copper - Posts: 72
Posted: April 14, 2010 at 5:31 PM / IP Logged
Ok.. need ideas how tos mount my sub boxs to my frame.. so it will sound better adn not be able to be thefted....im going to have 2 single boxs... in the back of my 2 door chevy 97 tahoe  . Now on the 2 door the gas tank is under the truck space... Pics adn ideas would be great...   I also have spare tire back there..  i want to be able to take that box out on the road if i need to change a tire..  I figure.. just 1 box is going to have to be removed to take out spare.. any ideas or pics would be great.. let me know.. thanks..
pitdawg47
Copper - Posts: 72
Posted: April 15, 2010 at 8:37 PM / IP Logged
has anyone seen any write ups on this anywhere?
pitdawg47
Copper - Posts: 72
Posted: April 17, 2010 at 11:20 AM / IP Logged
ok 3 days later?? does noone do this here?
pitdawg47
Copper - Posts: 72
Posted: April 18, 2010 at 9:19 AM / IP Logged
Help please?
anonymous1
Copper - Posts: 151
Posted: April 18, 2010 at 12:53 PM / IP Logged
Ok I'm going to just jump in here which verbiage which will keep me from getting my pants sued off.
Ideally, you have tied down in the Tahoe and could use tie down straps that you can buy in most any store. This may require the addition of adding the brackets to your boxes. This would in turn *IMHO* require you to pre drill the holes for the screws and use tapered 1" wood screws with brackets that would have tapered screw sockets. The size of the straps and harness configuration is up to you, and where you really want them secure enough for an accident.
I think what no one is willing to do is tell you to run screws through the floor of your Tahoe near the gas tank.
If you do not have tie downs, you could drill UP through the floor (or fender well) in some symmetrical way and add bolts with lock washers and some anchoring system, which again you can buy at most stores or a hardware store. Bolt heads would be at the top. If you don't think you'll ever want to take the tie down out, use some of that jb-weld type stuff or thread lock on the nut side.
Good luck!
pitdawg47
Copper - Posts: 72
Posted: April 19, 2010 at 12:46 AM / IP Logged
I have built in tie downs.. But i read somehwere else on this forum  that box should be mounted to frame if done right.. NOT to put straps .. It said you dont want box to move at all cause it will loose engery.. So the proper way is to mount it to frame...with some use of sheet metal..      Now i just need to know how its done!  Can someone help ??
anonymous1
Copper - Posts: 151
Posted: April 19, 2010 at 1:16 AM / IP Logged
Lose energy how? By jumping up and down?
Man you want to secure these so they don't KILL YOU.
And yeah, mouting to the frame would be ideal, but most of us don't have first hand knowledge of your frame.
You want this bolted to the frame, but . . . "I also have spare tire back there..  i want to be able to take that box out on the road if i need to change a tire..  "
Good luck with all that fabrication.
pitdawg47
Copper - Posts: 72
Posted: April 19, 2010 at 2:00 PM / IP Logged
ok sounds like this forum maybe cant help me then ..
anonymous1
Copper - Posts: 151
Posted: April 19, 2010 at 7:14 PM / IP Logged
I read the article you mentioned, and I don't dispute that securing to the frame would be a good idea if possible (minus the exploding gas tanks), but this is a 12v forum, not a "tahoe frame and modification" forum.
When I want to speak about thing pertaining to my Pathfinder, I post in the Nissan forums.
pitdawg47
Copper - Posts: 72
Posted: April 20, 2010 at 11:58 AM / IP Logged
i understand thanks for your help..
Saturday, June 8, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
