me design a lp variable cross
Member - Posts: 9
Posted: November 20, 2012 at 8:39 PM / IP Logged
i want to have a variable LP crossover for each channel. 125-60 variability and the other 70-30 or 2 at 125-30 variabilty. i would like to mod these into the dash or console of my 96 cherokee. i have the schimatics from my home audio powered sub amp board with a variable LP crossover if that will help.
honestly, i need someone to design it for me and possibly build it.
eric
682146989723
Member - Posts: 9
Posted: November 20, 2012 at 8:43 PM / IP Logged
it would be for 2 subs and will probably have to be active.
soundnsecurity
Gold - Posts: 2,720
Posted: November 21, 2012 at 9:29 AM / IP Logged
it would be much easier to buy an in-dash active crossover that will do what you want plus much more i suppose.
DYohn
Platinum - Posts: 10,741
Posted: November 21, 2012 at 10:01 AM / IP Logged
Ditto. Just get an electronic crossover. It's likely to be cheaper than what you can build and it would be guaranteed to work.
Member - Posts: 9
Posted: November 21, 2012 at 1:40 PM / IP Logged
i apreciate your posts.
if you can find  a unit that has 2 low pass channels that cover the frequency range i am interested in then i would buy it.  i've looked.  i even considered 2 one channel units and i did not come across those either.
DYohn
Posted: November 21, 2012 at 7:49 PM / IP Logged
Try an Audiocontrol Three.2, or a DQXS with dash control unit.
Member - Posts: 9
Posted: November 21, 2012 at 10:24 PM / IP Logged
thanks for the ideas but niether appear to have 2 low pass channels.
soundnsecurity
Gold - Posts: 2,720
Posted: November 22, 2012 at 5:51 PM / IP Logged
are you wanting to have a different crossover point for left and right sides? why?
682146989723
Member - Posts: 9
Posted: November 22, 2012 at 8:08 PM / IP Logged
i want to run one sub at a lower cut off than the other.  the lower frequencies are percieved quieter than the higher.  out of 2 speakers i will have the spl increase with the lower notes.  i have this set-up in practice in my home.  i also change the low pass of one of the subs to accomodate the style of music.  2 easy examples are rock/metal the low pass would be set around 110hz  and for rap/bass around 70hz.  those are liklely frequency ranges not something i would want on a switch.  as for the sub that i run at the lower frequency, i adjust that for environment accoustics.
DYohn
Posted: November 23, 2012 at 9:04 AM / IP Logged
So use 2 crossovers.... no big mystery.
