no audio
2010gmc
Posted: June 29, 2013 at 5:06 PM / IP Logged
Recently, I replaced a Custom Auto sound Head unit with a Retro-Sound head unit. I have a Eclipse 4 channel amp, a ten inch woofer,and a off brand subwoofer amp. After about a week, the audio quit working. The head unit and amps power-up, the mute control is off, but no audio unless the volume is up to maximum. Then you can just barely hear the audio like the amps are not boosting the signal. I have a 1956 210 Chevy.
DYohn
Platinum - Posts: 10,741
Posted: June 29, 2013 at 7:18 PM / IP Logged
Assuming the mute really is off, it sounds like the line outs on your head unit may have died.
soundnsecurity
Gold - Posts: 2,720
Posted: June 29, 2013 at 8:33 PM / IP Logged
also you can check the settings on your amp, sometimes there is a gain multiplier switch and you possibly pressed it by accident, this can cause it to seem like the audio is really low depending on how it was originally set.
also check the fade and balance settings on the radio, its possible that if the amps are being fed off of a single set of outputs then if you fade the audio all the way to the opposite output then it would cause the audio to be really low
2010gmc
Posted: June 29, 2013 at 11:36 PM / IP Logged
The only place there is a mute button is on the remote control. I put new batteries in it, and every function seems to work. I wish it was the mute button.
2010gmc
Posted: June 30, 2013 at 12:08 PM / IP Logged
Silver, Thank You for your response. I will check the fader and balance controls.
