how to wire up more than 2 sets of door speakers
ak609
Member - Posts: 47
Posted: November 30, 2015 at 7:06 PM / IP Logged Link to Post Post Reply Quote ak609
I have 3 sets of pioneer door speakers which can handle 35 watts rms. Since there are more than 4 speakers how would i wire these up to a amp and what kind of amp would i need? Thank you in advance its going into a limo.
http://www.pioneerelectronics.com/PUSA/Car/Speakers/A-Series/TS-A1372R?tab=specifications
ak609
Member - Posts: 47
Posted: November 30, 2015 at 7:14 PM / IP Logged Link to Post Post Reply Quote ak609
i believe i answered my own question by using a 2 channel amp use one channel for one set of 4 and the other channel for the other set of four. input would still be welcomed though please.
zmasta101
Posted: December 01, 2015 at 7:03 AM / IP Logged Link to Post Post Reply Quote zmasta101
For the amp input? If its a factory radio, use a line output converter to get old speaker wires converted to rca. Then hook those to amp. Otherwise some amps have a low level input, then u can skip the loc and hookip there
DYohn
Moderator - Posts: 10,741
Posted: December 06, 2015 at 10:27 AM / IP Logged Link to Post Post Reply Quote DYohn
If you would like your amplifier to last a while, be sure to wire your speakers for a net impedance load the amp can handle. Use the woofer wiring wizard in the left column if you need help. (Woofer are just speakers)
ak609
Member - Posts: 47
Posted: December 09, 2015 at 1:11 PM / IP Logged Link to Post Post Reply Quote ak609
yeah sorry was brain dead that day put the two rear door speakers on the rear part of the amplifier than put the front two sets of speakers on the front channel and just adjusted them till they were putting out the same sound with the gain levels. this was for a limo and it sounded awesome.
Tuesday, June 11, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
