Low Level Input, JBL GX-A3001, 2018 Ford F-350
johnnygaloshes
Member - Posts: 49
Posted: September 23, 2018 at 12:48 PM / IP Logged Link to Post Post Reply Quote johnnygaloshes
I have a JBL gx-a3001 that i am running one 12 inch sub-woofer at 2 ohms. I need to install it in my new 2018 F-350 and i am using the factory stereo. I want to use the line level input as the factory head unit does not have pre amps that i am aware. My question is, do i need to wire the left AND right speaker inputs or can it work with just one side being wired, sine i am using it as a mono amplifier. I'm going to use the rear speakers signal.
eguru
Copper - Posts: 340
Posted: September 23, 2018 at 5:29 PM / IP Logged Link to Post Post Reply Quote eguru
It is preferred to sum the L & R channels as input to the sub.
johnnygaloshes
Member - Posts: 49
Posted: September 24, 2018 at 11:27 AM / IP Logged Link to Post Post Reply Quote johnnygaloshes
What if i am using a speaker level to RCA adapter instead of the amplifiers internal one. I have seen a post online that some people have just used one speaker side for their speaker level input to the converter.
Platinum - Posts: 13,725
Posted: September 24, 2018 at 11:42 AM / IP Logged Link to Post Post Reply Quote i am an idiot
Line out converter or RCA jacks, it is better to catch both channels. Although the information at the frequencies your sub will play, there is not a lot of stereo information in the recordings. You may never hear a difference if you catch only 1 channel.
Sunday, March 1, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
