Kenwood KDC-X396, Clock Display
atikovi
Member - Posts: 30
Posted: March 22, 2021 at 8:27 PM / IP Logged Link to Post Post Reply Quote atikovi
Is there any way to have the clock displayed when the radio is off but car is running? I have the manual but there is no mention of it.
kenwood_nut
Stock Boy - Posts: 227
Stock Boy spacespace
Posted: April 01, 2021 at 11:43 AM / IP Logged Link to Post Post Reply Quote kenwood_nut
Based on my owning several Kenwood head units over the years including a few Excelon units, my guess is no, the clock won't stay on with the deck power turned off. In fact I haven't seen too many decks that have that feature. Most people wouldn't want their clock on all the time I'd guess. But it would be nice if we wanted to see the time!
atikovi
Member - Posts: 30
Posted: April 01, 2021 at 12:33 PM / IP Logged Link to Post Post Reply Quote atikovi
The radio has a constant 12V and an ignition switched 12V power supply. The clock would go off when you turn off the engine and leave the car.
kenwood_nut
Posted: April 02, 2021 at 12:34 AM / IP Logged Link to Post Post Reply Quote kenwood_nut
The yellow constant 12v wire provides power to the memory so you don't lose your radio presets or have to reset your clock every time you power up the deck, the red switched 12v wire just provides power to the deck when you're ready to play it. On ALL my decks since they 70's I've simply wired both of these together so I could listen to my music without having to have the key on. I still have to manually power it off. Regardless of how you wire it, there is no way to have just a clock displayed with the deck power turned off. I've never seen ANY brand of head unit that allows that feature. It would be nice, but none do it. I've been into car audio for 45 years and never found even ONE deck that let you do this. I would suggest just buying an external 12v digital clock and wiring it into constant 12v if you really want that clock.
