Install Pics - Post Pics Of Your Install
MBZ oe
Silver - Posts: 385
Posted: February 09, 2004 at 2:09 PM / IP Logged
Here's a pic of the finished trunk. I may make a door that opens with electric actuators to open. The box is mounted on heavy duty hinges with actuators to lift rear for spare tire access. Amps are Kicker, 1200.1 for subs and 300.4 for highs and mids. Head will be alpine CDA-7995 or Eclipse and is Sony right now. Capacitor is VooDoo 3F Rackmount. 0ga wiring with gold and platinum pro connections/distribution. Amp Rack is designed to be layered so I can eventually mount 2 more 1200.1's on the next amp rack layer so there will be one amp per sub. Three runs of 0ga are run to trunk and alternator is beefed with 0ga as well. Dynamat X-Treme was installed in entire car.
Install Pics - Post Pics Of Your Install -- posted image.
boom, boom, boom boom....
MBZ oe
Silver - Posts: 385
Posted: February 09, 2004 at 2:12 PM / IP Logged
Now the pic is there.
the12volt
Administrator - Posts: 3,955
Posted: February 09, 2004 at 2:15 PM / IP Logged
You need to make sure you do not have file extensions hidden for known file types or make sure the file extension is included in the path to your image when you upload it...    https://www.the12volt.com/installbay/forum_posts.asp?tid=21746&PN=1&fid=12&PR=3
Install Pics - Post Pics Of Your Install -- posted image. the12volt • Support the12volt.com
MBZ oe
Silver - Posts: 385
Posted: February 09, 2004 at 8:10 PM / IP Logged
Here is my battery compartment:
Wednesday, May 29, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
