Clarion DXZ635MP
mike ryan
Posted: May 21, 2004 at 12:58 AM / IP Logged
Hi,
I'm a newbie with a quick question:
I'm installing a Clarion DXZ635MP and I was wondering if anyone knows why there are two power wires.  One has a 15A fuse and the other has a 3A fuse.  Also, does anyone know what the brown wire is for?  It has the same connector on the end as the power antenna (blue), aux. on (blue/white), and illumination.
I've tried Clarion Canada's web site and I've tried searching the web, but I havn't been able to find any info.
Thanks,
Michael
thepencil
Gold - Posts: 1,526
Posted: May 21, 2004 at 8:44 AM / IP Logged
15A is your memory.
3A is your remote.
Hopefully this will help you out.
Here is the link.
http://www.clarion.com/usa/service/manual.htm
Clarion uses the industry standard wiring colors. Not every unit will have all of the listed wires
SPEAKERS:
White = Left Front +
WHITE/ Black = Left Front –
Gray = Right Front +
Gray/Black = Right Front –
Green = Left Rear +
GREEN/ Black = Left Rear-
Violet = Right Rear +
Violet/Black = Right Rear –
POWER/ACCESSORY:
Yellow 14ga = Battery Main/Memory
Yellow 18ga = Battery CeNET Power/Memory
Red = Accessory (ignition on)
Black = Ground
Blue = Antenna Turn On +
Blue/White = Remote Turn On (amps) +
ORANGE / White = Dimmer
Brown = Phone Mute
Orange or Mint Green= Parking Brake Video Lockout
WHITE/ Red = CCD (camera) input instant on +
RCA Cables:
Gray = Front Output
Black = Rear Output
Purple = Non-Fade or Subwoofer Output
Be careful whose advice you buy, but be patient with those who supply it.Clarion DXZ635MP -- posted image.
mike ryan
Posted: May 21, 2004 at 11:23 AM / IP Logged
Monday, May 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
