Home wiring question
chris_h
Copper - Posts: 50
Posted: January 06, 2005 at 3:04 PM / IP Logged
I'm wondering if home stereo speakers can be wired in different ways (series/parallel) to get more power out of the receiver, by dropping the impedance. Is this a sure way to fry the receiver? Also, if these are full range speakers, with crossovers built into the box, will this affect it too? Just curious.
When you step on the brakes your life is in your foot's hands
Francious70
Silver - Posts: 629
Posted: January 06, 2005 at 3:23 PM / IP Logged
Home Theatre recievers arn't usually meant to go below 4 ohms, so go with the normal wiring method. Not highly advisable, if you want more power, then go with a seperate amp and use the reciever as a pre-amp.
This is a good HT site & forum http://www.audioholics.com
Paul
DYohn
Platinum - Posts: 10,741
Posted: January 06, 2005 at 3:50 PM / IP Logged
And indeed many home amps and receivers will not handle less than 8 ohms.
chris_h
Copper - Posts: 50
Posted: January 06, 2005 at 6:12 PM / IP Logged
Thanks for the replies, and that link is just the place I've been looking for.
Francious70
Silver - Posts: 629
Posted: January 07, 2005 at 9:35 AM / IP Logged
It's no problem. I would rather answer the same question a hundred times over than see someone do a crazy thing like that and fry everything they spent their hard earned money on. It's so depressing to see someone loose all their hard work because of a little curiosity.
Paul
Friday, February 27, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
