4 Image Dynamics ID8v.3's, Distorted Sound?
tmorefi
Member - Posts: 31
Posted: May 23, 2005 at 12:10 AM / IP Logged
I just installed 4 Image Dynamics ID8v.3's and it doesn't sound very good. They sound pretty distorted when I'm pushing them. I'm using a Hifonics BX1500D amp. I know this amp has enough power but isn't the best quality. Could it truely be because of the amp quality? If I get a JL or other high end amp, will the sound be THAT much better? Right now I'm regretting getting this set-up instead of a couple 10's. Thanks for the help...
wrathchild281
Copper - Posts: 241
Posted: May 23, 2005 at 1:29 AM / IP Logged
i dont think that its the amp. How is it wired to your subs and what is the subs rms rating.
Alpine Guy
Platinum - Posts: 2,478
Posted: May 23, 2005 at 10:12 AM / IP Logged
how did you build the box? Separate chambers for each sub i hope.
stevdart
Platinum - Posts: 5,816
Posted: May 23, 2005 at 4:42 PM / IP Logged
RMS power handling for each sub is 150 watts.
http://www.imagedynamicsusa.com/products_page.php?id=id&type=sub
What do you have, the DVC 2 ohm or 4 ohm models, and how are the wired?  If you have the DVC 2's series/paralled to a final 1 ohm load on the amp, they're being overpowered.  Even if you have the DVC 4's series/paralled to a final 2 ohms, they're being overpowered.  You should have those subs at 3 to 4 ohms on that amp.
So, which ones do you have?
