1999 300m radio
tony.d
Member - Posts: 43
Posted: December 29, 2006 at 6:08 PM / IP Logged
i got the wiring harness together and on the back of the factory radio there is a singel wire purple and yellow stripe i beleive. It has a white connector on the end its on the driver side of the radion next to the black connector top corner, what is it? is it for the factory amp for the stock infinity sound system
tony.d
Member - Posts: 43
Posted: December 29, 2006 at 6:54 PM / IP Logged
that wire is not shown in the vehicle wiring guide either
geepherder
Platinum - Posts: 3,668
Posted: December 29, 2006 at 8:33 PM / IP Logged
If it's the lone wire that clips onto the back of the factory radio by itself, it's the ground. Notice there's no ground wire in your harness. You can either run your own, or put a male disconnect on the new radio's ground wire to connect to this one.
Saturday, June 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
