using a capacitor as a distributor block
oxygen65
Silver - Posts: 252
Posted: January 13, 2007 at 5:38 PM / IP Logged
i have 0 gauge wire ran in my car run into a 2.5 farad earthquake capacitor. what i was wondering is can i use the positive post from the capacitor as a ddistributor block with somethin like this?
http:///.com/Stinger-Dual-4-Gauge-Probatt-Ring-Terminal-PRODR4_W0QQitemZ170067914093QQihZ007QQcategoryZ50549QQrdZ1QQcmdZViewItem
or is it going to have some bad effects? i want it to run 2 amps off of or should i just get a fused distibutor block and split the 0 gauge into 2 4 gauge for my amps?
haemphyst
Platinum - Posts: 5,054
Posted: January 13, 2007 at 5:42 PM / IP Logged
Firstly, the12volt prohibits linking to eBay auctions - that's in the forum rules.
Secondly, if there are distribution block capabilities built INTO the cap, use em...
Thirdly, what bullet wound are you trying to cover with a capacitor bandaid? Have you not read all the cap-bashing threads we have had here? Use that cash, and BUY AN ALTERNATOR. That's all that is going to fix voltage problems in your car.
oxygen65
Silver - Posts: 252
Posted: January 14, 2007 at 3:22 PM / IP Logged
you know what is funny, i already have a new alternator in my car along with a yellow top, so i really dont think i have any "bullet wound" i am trying to cover up with a "bandaid"  i think if i wanted to use a cap in my car i think im allowed to its my car.  and even if i didnt keep the cap in my car i wouldnt have a voltage problem and if i was having a voltage problem in the subject part of this post it would proble say somethin like oh i dunno "voltage problem?"  not using a capacitor as a distributor block.
dont you think i know that if a cap has a distributor block built into it, that i could use it?  i think it takes a genius to figure that one out, but OBVIOUSLY I DO NOT HAVE A CAP WITH A DISTRIBUTOR BLOCK BUILT INTO IT!!! wow.  i was simply asking if it was safe to use somethin like what i had a link to, and holly crap if i used a link to a website. who cares what website it is to???  is it really that big of a deal that i just wanted to show someone a pic of what i was talking about, and it just so happend to be on ebay?  who cares?  you need to take it easy and chill out becuse all i was doin was asking a question that i was like 80% positive i could do.  a simple yes you can or no you cant do that that would work.  i dont need the 12 volt police on me for somethin stupid like what you just tryed to make it.
mike12volt
Copper - Posts: 98
Posted: January 15, 2007 at 8:34 PM / IP Logged
I believe you can use your cap post as distribution block/splitter. I could not get to your picture to see it. All it is, is parallel wiring with neg.
kirktcashalini
Silver - Posts: 492
Posted: January 15, 2007 at 8:44 PM / IP Logged
woah easy easy... Wire it in. If it works, it works, If not it looks pretty, either way you win, ok?
haemphyst
Posted: January 15, 2007 at 9:57 PM / IP Logged
I have NEVER said "Do not use a cap". I have ALWAYS said "A cap doesn't do what the retailers say it'll do for you", or basically that. The retailer's cap hype is literally a "band-aid on a bullet wound". You are absolutely correct. It IS your car, and it IS your money. PLEASE, by all means, buy the cap. But, I am not the only person here that believes that a capacitor is a waste of money. I was simply trying to find out why you believe you NEED a cap in the first place. If you WANT it, that's a different story; please, install it, and all God's blessings upon you in all your future endeavors.
Well, it seems you have already answered you own question by firing back at me. If there are capacitors with distribution capabilities out there, then it must be OK to use the positive (and negative, for that matter) terminals for distribution. Only problem I can see is that sometimes the terminal bolt will be a bit too short, and you run the risk of stripping the bolt hole, by not having enough thread left over after several terminals are installed. Just be careful how tight you crank down on 'em once your terminals are installed.
I don't care, but the12volt.com does. Why? I don't know, and I don't really care. I just follow the rules. You are attacking me as if I blocked your link... I didn't block it. It's automatically filtered by the servers.
Again, I don't care where you link... But you agreed to to abide by the rules (just like everybody else did...) of the12volt.com by signing up, and continuing to post here. I would happily look at any link you provide, as I was curious to see what you were referring to. I was only trying to help, and it is obvious to me that you took it wrong. If it matters to you at all, I did try to locate that item on eBay, OUTSIDE of your link. I did. I was honestly trying to help you, and as I said, I wanted to see what exactly it was to which you were linking.
Speaking of wow... If anybody needs to chill out, it's you. Really... I am not "the12volt police". I am just a member here, just as you are. As I said already, I was only trying to help, and apparently you took something that I said out of context. I still do not believe that my response was rude in any respect, and I do not feel I deserved this type of retaliatory response from you. From now on, I'll simply ignore any and all threads from you, and you'll never have to worry about me responding in ANY respect, let alone in a way you might consider rude.
Tuesday, May 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
