what amp for these subs?
craigpiper
Member - Posts: 11
Posted: May 10, 2007 at 4:44 PM / IP Logged
Hi guys,
i'm really sorry to ask this question and i know there are lots of other posts out there that explain how to work this out, but i am confussed?!?!?!?!?
I have two "AUDIOBAHN PERFORMER AWC12T" and
Fs  31.4 Hz
Qts  0.59
Qes  0.71
Qms 3.57
Vas (Liters) 69 Liters
Vas (Cu. Ft.) 2.45 Cu.Ft.
Re 3.3 ohms
Le 1.5 mH
Mmd 130 grams
Xmax +/- 8mm
RMS 500 Watts
Sd 0.051 M2
Freq. Resp. 25Hz-800Hz
Efficiency 92.9 dB
please, please help!!!!
thankyou!
aznboi3644
Gold - Posts: 2,600
Posted: May 10, 2007 at 5:15 PM / IP Logged
how much money do you want to spend?? What coil configuration and impedance are those subs??
craigpiper
Member - Posts: 11
Posted: May 11, 2007 at 2:17 AM / IP Logged
i dont want to spend more than $500 and i want them to sound as good as they can (i know there not the best subs in the world)
there 4ohm coils, not sure on the impedance so here is the link to the subs and the teck is on the bottome om the page. http://www.audiobahn.com/Audiobahn06/pages/woofers.html
DYohn
Moderator - Posts: 10,741
Posted: May 11, 2007 at 8:29 AM / IP Logged
You have two of them?  Then you will probably get best performance wiring them for 2-ohms each (voice coils in parallel) and putting the two woofers in series for a net 4-ohm load, and then purchasing a mono subwoofer amplifier for them.  But the real next question is what sort of enclosure are you planning?
haemphyst
Platinum - Posts: 5,054
Posted: May 11, 2007 at 10:22 PM / IP Logged
Ummm... Audiobahn? The BEST amp for them is the wall socket. (In Great Britain, you oughta be able to make some AWESOME sparks, with 240 volts!) Blow those things up, take 'em back to the store where you bought 'em, get a store credit, and buy a real woofer... (yes, I said a woofer, any decent SINGLE woofer will far outperform those boat anchors!) Something with a few less flames, and a whole LOT less chrome...
Sorry, that wasn't very helpful, was it? what amp for these subs? -- posted image.
craigpiper
Member - Posts: 11
Posted: May 12, 2007 at 5:28 PM / IP Logged
haemphyst, thanks for the construstive comments, but not everyone makes a choice knowing everything about everything and some people even have a budget!!!!!!!
What would you sujest then???
aznboi3644
Gold - Posts: 2,600
Posted: May 13, 2007 at 1:13 AM / IP Logged
If you want a budget amp.
http://www.online/CarAudio/ProductDetail.aspx?Productid=16696
If you want a good amp that will stroke those really quick
http://www.edesignaudio.com/edv2/product_info.php?cPath=21&products_id=44
I only suggest the ED amp because I have one and it is a beast. Some people on here may say ED sucks...well that was a few years ago and they had some problems. Now everything is good and very good quality. 5 year warranty also. And they pay for shipping whatever broke back to them for them to fix or replace.
