Posted: December 29, 2011 at 9:52 PM / IP Logged
Posted: December 29, 2011 at 10:25 PM / IP Logged
Posted: December 29, 2011 at 11:29 PM / IP Logged
Posted: December 30, 2011 at 5:35 AM / IP Logged
Posted: December 30, 2011 at 6:25 AM / IP Logged
Posted: January 17, 2012 at 8:42 AM / IP Logged
Posted: January 17, 2012 at 9:04 AM / IP Logged
Posted: April 05, 2015 at 1:26 AM / IP Logged
Wednesday, March 18, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
Remove 3 10mm bolts from metal support bracket (1 on left, 2 on right). Lift bracket and pull away.
Remove 2 panel clips on driver kick panel cover. Pull panel towards back of vehicle.
Wiring Information:
Ignition wires can be found in 2 small wire looms coming from ignition switch. Constant 12v and Starter are in one loom, Ignition, Accessory, 2nd Accessory are found in the 2nd loom.
Trunk/Hatch release wire is found at the release switch on the knee bolster panel.
Parking brake wire is found in the main harness coming up the driver kick panel.
Multiple wires found at factory alarm green connector in driver kick panel.
Brake wire found at cruise control unit in driver kick panel.
Clutch switch is located high above the clutch pedal. Will require some contorting and skill with a set of strippers to access and expose wires.
Tach signal found under hood behind driver side strut tower at test connector. There is a factory rubber boot directly above the driver kick panel that will lead directly to the tach test connector.
Thanks, Kenny!
