2004 hyundai accent
anthonylecuona
Copper - Posts: 51
Posted: January 25, 2008 at 5:38 PM / IP Logged
need rear defog info and dei says only the canadian models reqiure the transponder bypass how do i found out if it needs it or not does the key look different than normal or is there another way to find out?
In case of snow drive backwards, instant front wheel drive, then again who needs it when you drive a Scoobie
tedmond
Gold - Posts: 4,610
Posted: January 25, 2008 at 6:36 PM / IP Logged
wire up your remote start. Start the car with the remote start and if it starts you dont need a transponder. Also not for a theft light in the dash.
chadwa2003
Copper - Posts: 353
Posted: January 25, 2008 at 6:53 PM / IP Logged
None of the models that I have ever done have had a bypass and you should be able to get the rear defog wire at the switch
