code alarm mv 3
519civiconair
Copper - Posts: 50
Posted: January 28, 2008 at 3:55 PM / IP Logged
I have a viper 550 esp and code MV-3  it seems the output of the interior zone isnt long enough to trigger the full alarm anyone ran into this before and or know a solution THNX in advance
F.B.S.S air ride is the only way to roll
datadesign
Member - Posts: 6
Posted: January 30, 2008 at 8:02 PM / IP Logged
Are you sure the green and blue (int full and ext pre) wires are not reversed?
Do you have another sensor connected with the mv-3 to the 550 input port?  If so are you using diodes?
DataDesign
datadesign
Member - Posts: 6
Posted: January 31, 2008 at 11:26 AM / IP Logged
Also for got to mention - make surethatyour notin setup/test mode.  Make sure that sw1 and sw2 are both off or both on.
DataDesign
datadesign
Member - Posts: 6
Posted: January 31, 2008 at 7:13 PM / IP Logged
Let's try again - this time in english.
Also forgot to mention - make sure that your not in the setup / test mode.  Make sure that sw1 and sw2 are both off or both on.
DataDesign
519civiconair
Copper - Posts: 50
Posted: February 11, 2008 at 1:40 AM / IP Logged
Sorry for not getting back to this... my computer went in for upgrading....NEWAYS THNX for the reply...   The answer to is another sensor hooked up is YES and are they isolated YES it just seems like its not long enough to trigger the full alarm.  I have HUNDREDS of alarms,remote starts and sensors from Diff. manufacturers all of the dual zone motion sensors except the code alarm trigger the full alarm on ALL types of alarms/remote starts when hooked up to a harness  made up for two sensors. Any suggestions will be greatly appreciated as I hav a bunch of them and would like to be able to use them...  not just as a warn away...  although that would atleast help.
Saturday, April 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
