remote start probs
wes5314
Member - Posts: 26
Posted: January 29, 2008 at 11:25 AM / IP Logged
I have a bull dog rs82 remote start when i start the car it start no prob then after 10 to 12 sec then it cuts off then it restarts and so on any ideas ?its on a 93 geo prism
wes5314
brcidd
Copper - Posts: 274
Posted: January 29, 2008 at 12:33 PM / IP Logged
Since there is no bypasses needed for yor car- it sounds like the R/S doesn't know the car has started and is running-- so did you use tach sensing?  did you learn the tach?   or did you use voltage sensing?-- tach sensing is always the best way to assure your R/S knows the car is running
Brcidd - Engineer That Does Remote Starter Installs on the side.
wes5314
Member - Posts: 26
Posted: January 29, 2008 at 12:36 PM / IP Logged
no i used the tachless option
wes5314
brcidd
Copper - Posts: 274
Posted: January 29, 2008 at 1:12 PM / IP Logged
therein lies your problem-- try tach sensing...............
Sunday, April 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
