2008 acura tl remote start
meltingplastic
Copper - Posts: 225
Posted: January 30, 2008 at 7:43 AM / IP Logged
Hey guys, need wiring and bypass info on a 2008 Acura TL. Moms getting a new vehicle and the RS my aunt had the dealership on her 08 TL is a POS and a doodiety install so id rather just throw a DEI unit and call it a day.
-Mike
Driving a Bagged, Caddied 02 s10
Platinum - Posts: 12,488
Posted: January 30, 2008 at 8:37 AM / IP Logged
For the bypass module you can use the iDatalink ADS-DL that will take care of the immobilizer, locks, tach, door triggers, hood, trunk release & OEM alarm control.
12 VOLTS White Ignition switch harness    +
IGNITION BLACK / YELLOW Ignition switch harness    +
ACCESSORY BLACK/ red Ignition switch harness    +
STARTER BLACK/ white Ignition switch harness    +
KEY SENSE RED / white Ignition switch harness    -
TACH SIGNAL SEE NOTES
   Locate the PCM at the front floor of the center console. Remove the plastic cover on the passenger side to expose the connectors. On the 4 cylinder use Blue/red at pin 25 of the white plug. On the V6 use Blue at at pin 23 of the gray plug.
FUEL INJECTOR Opposite of BLACK / YELLOW At any injector on engine    AC
LOCK Pink/black In green plug on left side of fusepanel    -
   These wires are mastered from the passenger side switch, test wires using that switch.
UNLOCK Pink/blue In green plug on left side of fusepanel    -
DOORPIN GREEN/ red In green connector behind fusepanel    -
   Or independent negative door triggers at keyless module in driver kick panel: Green, GREEN/ red, GREEN/ YELLOW, GREEN / WHITE. Must diode isolate.
HOODPIN Yellow/red At hoodlatch in engine compartment    -
TRUNK PIN Blue/black In driver's kickpanel (harness to rear)    -
TRUNK RELEASE YELLOW /GREEN In driver's kickpanel (harness to rear)    -
   Also Blue / YELLOW in Driver kick pannel (+).
FACTORY ARM WHITE/ red At driver's door controller    -
   This module is part of the switch assembly inside the driver's door. You must run 2 wires through the door jamb boot.
FACTORY DISARM White At driver's door controller    -
BRAKESWITCH WHITE/ black At switch above brake pedal    +
PARKLIGHTS RED / black At top of fusebox or DKP    +
HORN GREEN/ YELLOW At steering column    -
VSS WIRE Blue/White At P.C.M.
   P.C.M. is located in front of center console and can be accessed from passenger side.
TRANSPONDER IGNITION Black At 7-pin plug on Ignition switch assembly    +
TRANSPONDER DATA 1 RED / blue Pin-2 at 7-Pin connector    DATA
TRANSPONDER GROUND BROWN / yellow At 7-pin plug on Ignition switch assembly    -
meltingplastic
Copper - Posts: 225
Posted: January 30, 2008 at 9:12 AM / IP Logged
Jeff, i have yet to get into firmware upgradeable bypasses as i stopped installing professionally around 2 years ago and only do a few side jobs every once and a while, if ordering from idatalink, will it come preflashed or do i still need to do the firmware on my own, FYI this bypass is pump!
Posted: January 30, 2008 at 11:29 AM / IP Logged
Depending on the module it will be preloaded or have nothing installed. Multi Series are not loaded while the Solo series will have firmware software loaded but may not be the most up to date.
Monday, April 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
