remote start on a 08 toyota tundra
mgortman
Member - Posts: 6
Posted: March 28, 2008 at 5:15 PM / IP Logged
im installing a python 881xp on a 08 toyota tundra but i can not fnd the wiring specs for it and also im installing window modules for 4 windows, sunroof and rear window. do anybody have the vehicle wiring diagram for this truck?
mg
Twelvoltz
Platinum - Posts: 2,384
Posted: March 28, 2008 at 5:32 PM / IP Logged
Audiovox Lists:
          #513625: 2008 TOYOTA TUNDRA 4DR TRUCK
     Audio/Mobile Video
     WIRE          COLOR          POLARITY          LOCATION
     Battery          BLUE          (+)          RADIO HARNESS
               FOR STANDARD AUDIO SYSTEM SEE THE EXTENDED CAB TUNDRA
     Accesory          GRAY          (+)          RADIO HARNESS
     Ground          WHITE/ BLACK          (-)          RADIO HARNESS
     Illumination          GREEN          (+)          RADIO HARNESS
     Amp Turn On
               THIS VEHICLE USES THE ACCESSORY POWER FOR AMPLIFIER TURN ON
     LF Speaker (+)          GREEN
               THESE WIRES SUPPLY THE AUDIO SIGNAL TO THE AMPLIFIER
     LF Speaker (-)          BLACK
     RF Speaker (+)          WHITE
     RF Speaker (-)          RED
     Amp Location          UNDER RIGHT FRONT SEAT UNDER PLASTIC COVER
     Steering Cntrls          OPTIONAL
     Speed Cntrl          OPTIONAL
     Radio Security          YES
     Security
     Battery          WHITE          (+)          IGNITION SWITCH HARNESS
     Ignition 1          LIGHT GREEN          (+)          IGNITION SWITCH HARNESS
     Starter 1          DARK GREEN          (+)          IGNITION SWITCH HARNESS
     All Door Trigger          ORANGE          (-)          AT COURTESY LIGHT UNDER DASH
     Domelight Super          GREEN          (-)          AT DOME LIGHT SWITCH ON DASH
               ALSO GRAY AT BODY ECU
     LF Latch          BROWN          (-)          IN HARNESS IN DRIVER KICKPANEL
               ALSO AT BODY ELECTRONIC CONTROL MODULE IN DRIVER KICKPANEL
     RF Latch          ORANGE          (-)          IN HARNESS IN PASSANGER KICKPANEL
     LR Latch          BLACK          (-)          IN HARNESS IN DRIVER KICKPANEL
               ALSO AT FUSE BOX IN DRIVER KICK PANEL
     RR Latch          BLUE          (-)          IN HARNESS IN PASSANGER KICKPANEL
     Hood Trigger          VIOLET          (-)          AT BODY ELECTRONIC CONTROL MODULE IN DRIVER KICKPANEL
               ALSO BLUE AT HOOD PIN SWITCH
     Alarm Disarm          BLACK          (-)          IN HARNESS IN DRIVER KICKPANEL
               WILL ALSO UNLOCK DOORS WITH A DOUBLE PULSE
     Alarm Arm          VIOLET          (-)          IN HARNESS IN DRIVER KICKPANEL
               WIRE WILL ALSO LOCK DOORS
     Parking Lights          GREEN          (+)          IN PLUG ON BOTTOM OF FUSE BOX
     Low Crr Pk Lights          ORANGE           (-)          AT VEHICLE LIGHT SWITCH
     Convenience
     Headlights-Lo          WHITE          (-)          AT VEHICLE LIGHT SWITCH
     Headlights-Hi          VIOLET          (-)          AT VEHICLE LIGHT SWITCH
     All Hazrd Lights          GRAY          (-)          AT VEHICLE HAZARD SWITCH
     Wipers-Lo          GREEN          (+)          AT VEHICLE WIPER MOTOR
     Wipers-Hi          RED          (+)          AT VEHICLE WIPER MOTOR
     Parking Brake          ORANGE          (-)          AT PARKING BRAKE SWITCH
     Seat Mem 1          PINK          (-)          AT SWITCH IN DRIVERS DOOR
     Seat Mem 2          ORANGE          (-)          AT SWITCH IN DRIVERS DOOR
     Remote Start
     Ignition 2          BLACK          (+)          IGNITION SWITCH HARNESS
     Accessory 1          GRAY          (+)          IGNITION SWITCH HARNESS
     Anti-Theft Type          UNIVERSAL IMMOBILIZER
     Anti-Theft Descript          THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
     Key Sense          GRAY          (-)          IGNITION SWITCH HARNESS
               ALSO LIGHT GREEN (-) AT BODY ELECTRONIC CONTROL MODULE
     Tachometer          WHITE          (AC)          AT DATA LINK CONNECTOR
               DATA LINK CONNECTOR IS LOCATED UNDER DASH ON DRIVER SIDE
     Speed Sense          YELLOW          (AC)          AT SKID CONTROL ECU AT BRAKE BOOSTER
               ALSO WHITE AT RADIO HARNESS
     Low Crr. Pk Lights          ORANGE           (-)          AT VEHICLE LIGHT SWITCH
     Brake Lights          ORANGE          (+)          AT SWITCH ABOVE BRAKE PEDAL
     Reverse Lights          BLUE          (+)          IN HARNESS IN DRIVERS KICKPANEL
     Horn          ORANGE          (-)          IN HARNESS AT STEERING COLUMN
               ALSO BLUE (+) AT VEHICLE HORN
     IMO          LIGHT BLUE          (DATA)          AT TRANSPONDER KEY ECU UNDER DRIVER SIDE DASH NEAR CENTER CONSOLE
     IMI          YELLOW          (DATA)          AT TRANSPONDER KEY ECU UNDER DRIVER SIDE DASH NEAR CENTER CONSOLE
     Modules
     WIRE          LOCATION
     Please select another category
     Doorlocks/Windows
     Power Unlock          RED          (-)          IN HARNESS IN DRIVERS KICKPANEL
     PowerLock          WHITE          (-)          IN HARNESS IN DRIVERS KICKPANEL
     Driver Mtr Unlock          PINK          (REV)          IN HARNESS IN DRIVERS KICKPANEL
     Driver Mtr Lock          WHITE          (REV)          IN HARNESS IN DRIVERS KICKPANEL
     LF Window Up          LIGHT GREEN          (REV)          AT MASTER WINDOW CONTROL SWITCH
     LF Window Dn          LIGHT BLUE          (REV)          AT MASTER WINDOW CONTROL SWITCH
     RF Window Up          YELLOW          (REV)          AT MASTER WINDOW CONTROL SWITCH
     RF Window Dn          GREEN          (REV)          AT MASTER WINDOW CONTROL SWITCH
     LR Window Up          VIOLET          (REV)          AT MASTER WINDOW CONTROL SWITCH
     LR Window Dn          BLACK          (REV)          AT MASTER WINDOW CONTROL SWITCH
     RR Window Up          ORANGE          (REV)          AT MASTER WINDOW CONTROL SWITCH
     RR Window Dn          LIGHT GREEN          (REV)          AT MASTER WINDOW CONTROL SWITCH
     Note: Audiovox makes no representation or warranty with respect to the above information including its accuracy, completeness, or its freedom from third parties' proprietary rights. Audiovox disclaims all liability or responsibility for errors or omissions therein or any decision made by the recipient in reliance thereon. The installer must verify any circuitry with the proper test equipment prior to installation.
mgortman
Member - Posts: 6
Posted: March 28, 2008 at 9:13 PM / IP Logged
thanks for the info
mg
mgortman
Member - Posts: 6
Posted: April 11, 2008 at 12:34 PM / IP Logged
 ok everything done on the truck except the rear window and the sunroof . i found the wires but i cant get them to work with the 529t .
mg
Friday, May 31, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
