what bitwriter version for 50.7x?
johnc123
Posted: November 29, 2009 at 8:07 PM / IP Logged
Just finished a Clifford 50.7X install in my 2004 Tundra Doublecab.  Everything works, but it's very tedious to try to program all of the features using the valet switch and chirps.  I wouldn't mind picking up a used unit off Ebay if I was sure the chip version would work with the 50.7X.  Does anyone know what version I need?  Thanks.
PS - the information I found on this website was a big help, as this was my first alarm/keyless entry/remote start install.
calitech247
Copper - Posts: 68
Posted: November 29, 2009 at 8:52 PM / IP Logged
Here's some useful info in the 50.7X installation manual. I just copy and paste here for ya...
Bitwriters require software v2.6. Bitwriters with a date code of 6a or older
require an IC upgrade (p/n 998M). Some Bitwriters with a date code of 6B
do not require the IC upgrade, refer to tech tip # 1112 for more information.
Bitwriter 2 compatible.
johnc123
Posted: November 30, 2009 at 7:03 AM / IP Logged
Thanks for the reply.  I looked all through my manuals again, and found the information you posted inside the front cover of the installation guide.  Now I'll try to find tech tip #1112 and see what it says.
calitech247
Copper - Posts: 68
Posted: November 30, 2009 at 1:01 PM / IP Logged
Ok...glad to help.  I'll try to see if I can get the tech tip and send it via email. email address?
johnc123
Posted: November 30, 2009 at 2:32 PM / IP Logged
I was able to locate a copy of the tech tip, it deals with figuring out which version you have and how to upgrade it.  Thanks again for the help.
Tuesday, May 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
