2010 ford expedition wiring
isa-kuruption
Member - Posts: 18
Posted: January 14, 2010 at 3:01 PM / IP Logged
I see there's info posted for the 2008 Expedition, but not the 2010. I want to confirm the diagram information is the same. Does anyone have any information for the 2010 model? Thanks.
chev104275
Gold - Posts: 1,428
Posted: January 14, 2010 at 4:04 PM / IP Logged
2009 FORD EXPEDITION 4DR SUV
Security
WIRE COLOR POLARITY LOCATION
Battery BLUE/RED (+) IGNITION SWITCH HARNESS
Ignition 1 WHITE/ ORANGE (+) IGNITION SWITCH HARNESS
Starter 1 BLUE/WHITE (+) IGNITION SWITCH HARNESS
All Door Trigger GRAY/VIOLET (+) IN HARNESS IN PASSENGER KICKPANEL
Domelight Super GREEN/ BLUE (-) AT MODULE IN PASSENGER KICKPANEL
LF Latch GREEN/ VIOLET (-) AT MODULE IN PASSENGER KICKPANEL
   ALSO IN HARNESS IN DRIVER KICKPANEL
RF Latch WHITE (-) AT MODULE IN PASSENGER KICKPANEL
LR Latch YELLOW (-) AT MODULE IN PASSENGER KICKPANEL
RR Latch GREEN (-) AT MODULE IN PASSENGER KICKPANEL
Trunk Trigger GRAY/ORANGE (-) AT MODULE IN PASSENGER KICKPANEL
Parking Lights VIOLET/WHITE (+) AT MODULE IN PASSENGER KICKPANEL
Low Crr Pk Lights BLUE/GRAY (-) AT VEHICLE LIGHT SWITCH
Convenience
Headlights-Lo YELLOW/BLUE (-) AT MODULE IN PASSENGER KICKPANEL
   ALSO AT VEHICLE HEADLIGHT SWITCH
Headlights-Hi YELLOW/VIOLET (+) AT MODULE IN PASSENGER KICKPANEL
LF Pk Lt Bulb VIOLET/WHITE (+) FRONT LEFT PARKING LAMP
RF Pk Lt Bulb VIOLET/WHITE (+) FRONT RIGHT PARKING LAMP
LR Pk Lt Bulb VIOLET/WHITE (+) AT REAR LEFT TAILLIGHT ASSEMBLY
RR Pk Lt Bulb VIOLET/WHITE (+) AT REAR RIGHT TAILLIGHT ASSEMBLY
All Hazrd Lights GREEN/ ORANGE (-) AT VEHICLE HAZARD SWITCH
LF Hazrd Bulb BLUE/GREEN (+) AT FRONT LEFT TURN LAMP
RF Hazrd Bulb YELLOW/VIOLET (+) AT FRONT RIGHT TURN LAMP
LR Hazrd Bulb GRAY/BROWN (+) AT REAR LEFT TAILLIGHT ASSEMBLY
RR Hazrd Bulb VIOLET/ORANGE (+) AT REAR RIGHT TAILLIGHT ASSEMBLY
Wipers-Lo BLUE/ORANGE (-) AT WIPER CONTROL SWITCH
Wipers-Hi VIOLET/ORANGE (-) AT WIPER CONTROL SWITCH
Parking Brake VIOLET/BROWN (-) AT VEHICLE PARKING BRAKE SWITCH
Trnk Release BROWN (-) AT MODULE IN PASSENGER KICKPANEL
   FOR GLASS RELEASE USE BROWN / YELLOW (-) AT MODULE IN PASSENGER KICKPANEL
Seat Mem 1 VIOLET/WHITE (-) AT MODULE UNDER DRIVER SEAT
Seat Mem 2 YELLOW (-) AT MODULE UNDER DRIVER SEAT
Remote Start
Accessory 1 BROWN / YELLOW (+) IGNITION SWITCH HARNESS
Accessory 2 VIOLET/GREEN (+) IGNITION SWITCH HARNESS
Anti-Theft Type FORD PATSŪ OR SECURILOCKŪ VEHICLE IMMOBILIZER
Anti-Theft Descript THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
Key Sense BLUE/GRAY (+) IGNITION SWITCH HARNESS
Tachometer GRAY / YELLOW (AC) AT PCM MODULE UNDER HOOD ON PASSENGER FENDER
Speed Sense YELLOW/BLUE (AC) AT PCM MODULE UNDER HOOD ON PASSENGER FENDER
Low Crr. Pk Lights BLUE/GRAY (-) AT VEHICLE LIGHT SWITCH
Brake Lights YELLOW/GRAY (+) AT SWITCH ABOVE BRAKE PEDAL
   ALSO AT MODULE IN PASSENGER KICKPANEL
Reverse Lights GREEN/ BROWN (+) IN HARNESS IN PASSENGER KICKPANEL
Horn YELLOW/RED (-) IN HARNESS AT STEERING COLUMN
Rear Defrost WHITE/ ORANGE
Doorlocks/Windows
Power Unlock BLUE/BROWN (-) AT MODULE IN PASSENGER KICKPANEL
PowerLock WHITE/ BROWN (-) AT MODULE IN PASSENGER KICKPANEL
Driver Mtr Unlock GRAY/BROWN (REV) IN HARNESS IN DRIVER KICKPANEL
Driver Mtr Lock BLUE/GREEN (REV) IN HARNESS IN DRIVER KICKPANEL
Pas Mtr Unlock GRAY/BROWN (REV) IN HARNESS IN PASSENGER KICKPANEL
Pas Mtr Lock VIOLET/GRAY (REV) IN HARNESS IN PASSENGER KICKPANEL
LF Window Up BLUE/GRAY (REV) AT DRIVER WINDOW SWITCH
LF Window Dn YELLOW/VIOLET (REV) AT DRIVER WINDOW SWITCH
RF Window Up BROWN / YELLOW (REV) IN HARNESS IN DRIVER KICKPANEL TO DOOR
RF Window Dn GREEN/ ORANGE (REV) IN HARNESS IN DRIVER KICKPANEL TO DOOR
LR Window Up BLUE/ORANGE (REV) IN HARNESS IN DRIVER KICKPANEL TO DOOR
LR Window Dn YELLOW (REV) IN HARNESS IN DDRIVER KICKPANEL TO DOOR
RR Window Up GRAY/VIOLET (REV) IN HARNESS IN DRIVER KICKPANEL TO DOOR
RR Window Dn BROWN / GREEN (REV) IN HARNESS IN DRIVER KICKPANEL TO DOOR
Sunroof Open VIOLET/WHITE (REV) IN OVERHEAD CONSOLE SWITCH
Sunroof Close YELLOW/ORANGE (REV) IN OVERHEAD CONSOLE SWITCH
this is for a 2009 should be close to the 2010 if not the same
isa-kuruption
Member - Posts: 18
Posted: January 14, 2010 at 6:53 PM / IP Logged
Thanks a lot!
Quick question: Trunk trigger (first grouping) which is the Grey/Orange, is that an indicator as to whether the trunk/liftgate is open or closed, or the trigger to open the liftgate (as opposed to the brown in the second grouping which is labeled trunk release)?
chev104275
Gold - Posts: 1,428
Posted: January 14, 2010 at 8:34 PM / IP Logged
trunk trigger Gray/orange is the wire that tells your alarm the trunk is open
trunk release is the wire that activates the truck motor to open the trunk
Wednesday, May 29, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
