home depot wire for car alarm?
sparky23
Member - Posts: 8
Posted: January 24, 2010 at 3:10 PM / IP Logged
The guy at Home Depot said I could use their wiring for a car alarm install.  I am getting 10 and 18 gauge.  Is that wire ok to use?  If not why?
JWorm
Platinum - Posts: 2,208
Posted: January 24, 2010 at 3:18 PM / IP Logged
Depends what it is. Wire with a lot of strands of copper is better because it is more flexible. Single stranded wire can work, but it doesn't bend very well. You probably won't be adding much wire besides what comes with the alarm.
Mike M2
Platinum - Posts: 2,652
Posted: January 24, 2010 at 3:38 PM / IP Logged
i own a small boat repair business here on the Chesapeake, and like boats a car requires a very flexable wire. The more strands in the wire the better for a environment that moves and vibrates. A single strand is a no, just won't hold up to bumps and moves. You need a wire that flexes, the more the better it will work. That said, the more flex and the more it costs....
Mike M2
Tech Manager
CS Dealer Services
Posted: January 24, 2010 at 4:34 PM / IP Logged
Depending on the alarm's make I always find excess wire I can use e.g. DEI with the green and violet wires for neg. and pos. door triggers. You will only use one of them so take the unused length to add to say the trunk trigger wire to extend it. I have a large bag in my car choc- bloc with odd cable lengths. The only reels I have are blue, green, black and red but I hardly ever need to use them.
Mike is right NEVER use solid core in a car, it can break. probably a
Mike, is there a conversion chart for cable sizes, wire gauge to the ISO system at a guess, 18 gauge is about 0.75mm but I'm not sure, I can do spanner sizes, AF to metric in my head but I can't work it out!
Platinum - Posts: 7,828
Posted: January 24, 2010 at 5:29 PM / IP Logged
Try this for wire gauge conversions:
http://www.reade.com/Conversion/wire_gauge.html
Posted: January 24, 2010 at 6:29 PM / IP Logged
Thanks kreg357, I've pasted it as a file.
tommy...
Gold - Posts: 1,901
Posted: January 25, 2010 at 9:23 AM / IP Logged
http://bcae1.com/wire.htm
M.E.C.P & First-Class
