2009 jeep grand cherokee, viper 5901
android67
Member - Posts: 12
Posted: July 08, 2010 at 11:36 AM / IP Logged
Ok guys great thread/forum you have!
Before starting the installation wanting to confirm I have all in order.
Installation for a 2009 Jeep Grand Cherokee Limited:
1) Viper 5901
2) CANMAX400DEI
        a. will flash firmware (400.CHRYSLER_2.01) with XpressKit XKLOADER2
Now do I still require to purchase a "Bitwriter 2.7" to program the Viper 5901?
Thanks for any assistance you can provide.
From the desert...
angelars
Copper - Posts: 176
Posted: July 08, 2010 at 11:57 AM / IP Logged
The bitwritter makes it very easy to program the 5901. It's a pain to do it without one. I am glad I bought one or half the things on our 5901 would never have been set up right.
Troc4434
Copper - Posts: 68
Posted: July 08, 2010 at 12:02 PM / IP Logged
1) Viper 5901
2) CANMAX400DEI
From the desert...
I think you still will need the key bypass so you dont have to leave a key in the car to remote start. You can program the brain with the push button that does the programming. But you have to know how many presses to each options when set. the bitwriter would be the easy way of programing. That what I use.
android67
Member - Posts: 12
Posted: July 08, 2010 at 12:11 PM / IP Logged
Yes I was wondering about the key bypass as I would prefer not to leave a key in the vehicle for remote start ( defeats the purpose of security)
So the Bitwriter could program the Viper 5901 brain, not require a key bypass?
Or is the bypass still required and the bitwriter makes the programming simple?
android67
Member - Posts: 12
Posted: July 08, 2010 at 3:06 PM / IP Logged
Ok, did some more digging on the net.
Seems yes the Bitwriter is definately on the purchase list and also as TROC4434 wrote I should also purchase the DEI XKEYCHGM for this 2009 Jeep.
Sounds great,,, looking like that may be the final piece of the puzzle for orders.
Let you know once everything arrives here in the desert...
hurleyloser
Copper - Posts: 157
Posted: July 09, 2010 at 12:40 AM / IP Logged
you DO NOT need anything other than the CANMAX400 for this vehicle as far as the key bypass goes. The CANMAX400 will do the bypass through the CAN bus.
MECP Master Certified Technician
ASE A6 Certified Technician
android67
Member - Posts: 12
Posted: July 09, 2010 at 3:23 AM / IP Logged
Ok now I am confused as two 12volt posters have opposite recommendations:
Also the product XKEYCHGM states it is compatible with the CANMAX400DEI.
Why would the manufacture state it is compatible if not required?
If this is a matter of having a key in the ignition; I would prefer to have the XKEYCHGM installed with the CANMAX400DEI for obvious security reasons.
Unless I am incorrect, please advise the purpose of the XKEYCHGM?
android67
Member - Posts: 12
Posted: July 11, 2010 at 11:03 AM / IP Logged
Viper 5901
CANMAX400DEI
Attempting to flash the CANMAX400DEI while it is docked in the V5901.
Screen states USB Loader is connected.
Current Directed Module Detected states the following:
Platform: 400
Firmware: N/A
Bootloader: N/A
Clicking "Refresh Information" creates an error message - Refresh Failed - The Operation as timeout.
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Tuesday, May 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
