Posted: August 08, 2010 at 4:31 PM / IP Logged
Posted: August 08, 2010 at 5:03 PM / IP Logged
Posted: August 08, 2010 at 5:22 PM / IP Logged
Posted: August 08, 2010 at 6:58 PM / IP Logged
Friday, April 17, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
the only thing I think it could be is the ignition wire or accessory/blower wire. But I put a multimeter to the ignition wire and pressed the start button and no voltage was read through that wire (Both accessory/blower and ignition wire are connected at bcm, not ignition if that could make a difference?). Could the remote start module just be bad? This is puzzeling me. The starter wire is not connected because I read that it doesn't need to be wired for the cobalts.
