94 explorer and avital 4103
sergeant_a
Posted: January 02, 2011 at 10:44 AM / IP Logged
I installed an Avital 4103 in my 94 explorer yesterday but cannot get my door lock/unlock or the horn to work. Does anyone have any suggestions or what wires I should be hooking them up to. I hooked up to Pink / YELLOW and pink/green in the drivers panel for the locks and what looks to be yellow/blue in the column for the horn(everything says it should be yellow green but cannot find a find one only the yellow/blue coming down from the horn) I do not have key;ess entry and would really like to get these features working. I have read that I may possibly need relays but the guy at the store said that I do not need any additional stuff for the install when I bought it. So far everything else works.
chev104275
Gold - Posts: 1,436
Posted: January 02, 2011 at 11:07 AM / IP Logged
POWER LOCK PINK / YELLOW (TYPE C) See NOTE *1   IN DRIVERS KICK PANEL
POWER UNLOCK PINK/LIGHT GREEN (TYPE C) See NOTE *1   IN DRIVERS KICK PANEL
NOTE *1 Vehicles with KEYLESS ENTRY are TYPE B, Vehicles without KEYLESS ENTRY are TYPE C. Vehicles with the KEY PAD on the Door are considered to have KEYLESS ENTRY
Type C Door Lock Wiring
Horn Should be YELLOW /GREEN in the steering column harness just keep looking
zerepdivad
Silver - Posts: 605
did your vehicle have factory keyless entry? if not i'm pretty sure you need to do a 5 wire setup for locks. how did you test the wires that you hooked to? did you test?
A DMM is a beautiful thing.
