viper 5101 remote start
k1500hd
Posted: October 09, 2011 at 1:39 PM / IP Logged
Viper remote has 2 car operation . While I was reprograming the remote start for the 2nd car. I deleted remote for system and I can't get it to reporgram.
performance713
Member - Posts: 19
Posted: November 14, 2011 at 6:53 PM / IP Logged
1. Hold the (F) button on the remote until the transmit LED lights solid (approximately 10 seconds).
2. Press one time the (remote start) (AUX)
until the amber Transmit LED lights up orange.
3. Next enter the remote control learn routine.
1. Insert the key. Turn the ignition to the ON
position. The heavy gauge pink wire must be connected.
2. Choose. Within 10 seconds, press and release the
Program switch two times and hold on the second time
3. when alarm respond push the lock button on the remote and the alarm should respond 1 chirp
4. close key and test it.
home this helps
im ( J ) and car audio is my thang.. and if i can help i will.
Monday, March 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
