2005 trailblazer remote start
eanderson651
Member - Posts: 41
Posted: November 30, 2011 at 1:49 PM / IP Logged
Hey all
Im planning to install a remote start (Viper 5301) on a 2005 trailblazer this weekend.  I'll be using the DB-ALL from DEI in D2D mode.
I'm looking at the install guide for that on xpresskit.com
I'm wondering if I have to use TX and RX wires?  The install diagram kind of shows i but doesn't say where those wires are in the truck.  Besides that, it looks like the DB-All only needs 12v + and - along with the OBD connection.  Is that all I need?  I know I still need to hook up the heavy gauge wires on the remote start, but not sure about the others.  Any input or tips would be appreciated.
Platinum - Posts: 7,802
Posted: November 30, 2011 at 1:59 PM / IP Logged
Everything is handled by the OBD2 connection and the D2D harness.  The 4 Pin connector shown with RX and TX is the D2D connector to the Viper.
Your Trailblazer is Passlock2 ( no transponder ).
Just make sure the DB-ALL is "Flashed" with the correct firmware ( 401.GM1 v1.04 ).
Posted: November 30, 2011 at 2:03 PM / IP Logged
The Viper will still need to be connected to the ignition wires, Chassis Ground, Parking Light, Brake, Horn ( optional ), and Hood Pin.
eanderson651
Member - Posts: 41
Posted: November 30, 2011 at 2:12 PM / IP Logged
Thanks so much for the quick reply, thats what I figured but wanted to be sure.
Sunday, November 10, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
