09 denali hatch release and liftgate
jonyb
Copper - Posts: 60
Posted: December 25, 2011 at 9:06 PM / IP Logged
2009 Yukon Denali with power liftgate and separate hatch release
Clifford 50.7X
ADS-ALSL-GM
Wire to wire
I tied the RED / white (trunk release from the Clifford) to the RED / white (on ADS)
also connected the aux 2 from Clifford to the brown "tailgate window release".
When I activate auxiliary 1, both the liftgate goes up, and the hatch opens.
What gives?
Everything else works like a charm.
John Bauer
Pro Installz
Paducah, KY
Platinum - Posts: 13,726
Posted: December 26, 2011 at 4:35 AM / IP Logged
AUdiovox says Pink Or Grey.  DId you possibly read that as Pink and Grey?
Note reads:  PINK IS GLASS RELEASE, GRAY IS HATCH RELEASE
jonyb
Copper - Posts: 60
Posted: December 26, 2011 at 6:01 AM / IP Logged
Nevermind, I just realized that there are 2 wires for auxiliary 1 on the 50.7X.
John Bauer
Pro Installz
Paducah, KY
jonyb
Copper - Posts: 60
Posted: January 02, 2012 at 10:42 PM / IP Logged
went back today and tried to fix it.  I thought I had both aux 1 wires connected to powerliftgate and hatch, but now there is only one wire connected, and the problem is still there.
2009 Yukon Denali
Clifford 5702X
AL-SLGM
Hardwired
RED / white (aux 1) from Clifford to RED / white (power liftgate) on ADS
Having a problem when I press the aux 1 function, the power liftgate and hatch both open at the same time. I originally had WHITE/ violet (Clifford) to Brown (ADS), but realized that the WHITE/ violet was a negative trigger for relays on aux 1. I went back and clipped that wire, and the problem is still there.
Any thoughts or suggestions?
John Bauer
Pro Installz
Paducah, KY
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
