I have been searching the forums and have gotten answers to many of my questions but would appreciate a double check of my wires I have listed and to see if anyone could assist with the ones I am not sure of. The following is a list on the harnesses and labels from the Viper 5904 System and the wires from the vehicle. Install is in a 2004 Ford F350 CrewCab Diesel- Automatic Transmission. Any help is greatly appreciated.
Main Harness
H1/1 Red 12+ Constant Input- Constant +
H1/2 Black - Chassis Ground
H1/3 Brown - Siren Output - Siren +
H1/4 WHITE/ Brown Parking Light Isolation Wire- Pin 87a of Onboard Relay NOT USED
H1/5 White Parking Light Output Brown Behind Dimmer Switch Panel
H1/6 Orange (-) 500mA Ground When Armed Output - NOT USED
Door Lock Harness
1 Blue (-)500mA Unlock Output - BLACK/ White - VSM
3 Green (-)500mA Lock Output - WHITE/ Red - VSM
Remote Start Harness
H3/1 Pink Ignition 1 Input/output -WHITE/ Yellow
H3/2 RED / White Fused (30a) Ignition 2/ Flex Relay Input 87 Constant +
H3/3 Orange Accessory Output - Gray / YELLOW
H3/4 Violet Starter Output (Car Side of Starter) - Green
H3/5 Green Starter Input (Key Side of Starter) - Green
H3/6 Red Fused (30a) Ignition 1 Input - Constant +
H3/7 Pink/White Ignition 2 / Flex Relay Output - RED / Black
H3/8 Pink/Black Flex Relay Input 87a Key side If required of Flex Relay -Not Used
H3/9 RED / Black Fused (30a) Accessory/Starter Input Constant +
24 Pin Harness
1 Pink/White (-)200mA Ignition 2/Flex Output- Not Sure ?
2 Blue/White (-)200mA 2nd Status/Rear Defogger Output -Not Used
3 RED / White (-)200mA Trunk Release -Not Used
4 BLACK / YELLOW (-)200mA Dome Light Status - Blk/Lt Blue-Pass kick panel Follow Below
Relay Pin 86 and 87 to +12V constant fused @ 5 Amps
-Relay Pin 85 to H2/4 -Relay Pin 30 to Truck BLACK/ Light Blue (+)
5 Dark Blue (-)200mA Status Output Not Sure ?
6 WHITE/ Black (-)200mA Aux 3 Output -Not Used
7 WHITE/ Violet (-)200mA Aux 1 Output - Not Used
8 ORANGE / Black (-)200mA Aux 4 Output - Not Used
9 Gray Hood Pin
10 Blue Trunk Pin/Instant Trigger Input -Not Used
11 WHITE/ Blue Activation Input - Not Sure?
12 Violet/White Tachometer Input - GREEN / WHITE Behind Fuse Panel
13 BLACK/ White Neutral Safety/Parking Brake Input Ground for Automatic Transmission
14 GREEN/ Black (-)200mA Factory Alarm Disarm Output - Not Used
15 Green (-) Door Input Not Sure ?
16 BROWN / Black (-)200mA Horn Honk Output - Dark Blue
17 Pink (-)200mA Ignition 1 Output Not Sure?
18 Violet - (+) Door Input Not Sure?
19 Violet/Black - (-)200mA Aux 2 Output - Not Used
20 Brown (+) Brake Shutdown Input - Light Green Brake
21 Violet / YELLOW (-)200mA Starter Output Not Sure?
22 Gray/Black (-) Diesel Wait to start Input - Not Used Use Delay timer
23 Orange (-)200mA Accessory Output - Extra ACC2 Relay
Follow Below
Relay Pin 85 to H2/23 Orange -Relay Pin 86 and 87 to +12V constant
-Relay Pin 30 to Acc2 BLUE/LT GREEN @ ignition harness
Relay Pin 87a not used - insulate
24 GREEN / WHITE - (-)200mA Factory Alarm Arm Output - Not Used
As you can See I have 7 Wires From the 24 pin harness I am not sure if are used or not. Do the 1 and 17 wires connect to the remote start wires or are those there to be used if the flex relay is used?
