2010 f150 raptor, can not program dball2
jimpap75
Member - Posts: 16
Posted: December 20, 2013 at 1:47 PM / IP Logged
I had a reputable installer install my Viper 5904 alarm in my F150 however they are not a dei authorized installer. Everything seems to be working even my smartstart but I can not get past steps 3&4 programming the dball2. I flashed the module myself but there are options to check off and I didn't know what they did so I left them checked. I tried both d2d & w2w with same results. Light on dball2 stays constant red. I did talk to an authorized installer and they said the dball2 may be bad. They want to sell me one already flashed for $75. Any advice would be greatly appreciated. Also I am using the 2 key programming method. Is it possible that the dball2 is not compatible with my truck? I wish I found this site before because I would have installed the alarm myself.
jimpap75
Member - Posts: 16
Posted: December 21, 2013 at 10:15 AM / IP Logged
Anyone think the dball might be bad?
prdjr165
Copper - Posts: 293
Posted: December 21, 2013 at 10:54 AM / IP Logged
the last DBALL i used was missing the red wire on the blue plug-once i had that fixed it worked...so check all your plugs/wires...
jimpap75
Member - Posts: 16
Posted: December 21, 2013 at 11:18 AM / IP Logged
Just checked and all the plug wires seem to be intact. The red wire on the blue plug is there as well.
Platinum - Posts: 7,802
Posted: December 21, 2013 at 11:43 AM / IP Logged
A few possibilities...
1.  You must have two, unique chipped keys to do the programming.  If you are using the original Ford factory keys,
     then you should be good to go.
2.  At steps 3 and 4 watch the instrument panel security light.  It should go out a few seconds after the key is inserted
     and turned to ON.  That is when you should remove the first key and do the second key, etc.
3.  Double check your connections to the TX and RX wires.  They should be soldered.  Here is some info from notes
     on a 2010 F150 ( Non-Raptor ) XLT :
       RX = Pin 4 = Yellow/Orange
       TX = Pin 3 = Violet/Gray
4.  Finally, any DB-ALL2 LED flashes during programming?  There is a chart on Page 18 of the install guide that might
     give you an indication of the proble.
jimpap75
Member - Posts: 16
Posted: December 21, 2013 at 11:46 AM / IP Logged
Mine is a Raptor.
jimpap75
Member - Posts: 16
Posted: December 21, 2013 at 11:52 AM / IP Logged
Mine is a Raptor.
Both my keys are original Ford keys and during steps 3&4 the security light on the dash goes out but the light on the dball stays solid red. I am thinking that the dball was wired for a regular f150 not a Raptor.
jimpap75
Member - Posts: 16
Posted: December 21, 2013 at 12:08 PM / IP Logged
Also on the diagram I have RX is pin 3 and TX is pin 4.
jimpap75
Member - Posts: 16
Posted: December 21, 2013 at 12:10 PM / IP Logged
Sorry made a mistake, you're right RX is pin4 and TX is pin 3. I am going to double check right now to make sure they are in the correct pins.
jimpap75
Member - Posts: 16
Posted: December 21, 2013 at 12:27 PM / IP Logged
Just confirmed that RX & TX are in the correct pins.
