rav4 compustar problem
yyqq
Member - Posts: 6
Posted: November 09, 2014 at 8:20 PM / IP Logged
Hi. I just installed a compustar with blade-al to a 2012 Rav4.for a few times, I found the car start again after I shut off the car. the only thing I am not very sure is remote starter main harness connection. there are two starter and two ignition wires. I use compustar provided relay with +12v and 2nd starter output from blade for 2nd starter. and as well for 2nd ignition. I used tachless mode.
any help is appreciated. thanks
yyqq
Member - Posts: 6
Posted: November 09, 2014 at 9:20 PM / IP Logged
I forgot to mention that the 2 remote were on the table. nobody touched that. I turned off the car and car started again after 10 seconds.
prdjr165
Copper - Posts: 293
Posted: November 10, 2014 at 8:03 AM / IP Logged
which compustar model did you use ?
yyqq
Member - Posts: 6
Posted: November 10, 2014 at 9:47 AM / IP Logged
thanks for replying. I used FT-6200-CONT. the remote was RF-1WG6-AM
prdjr165
Copper - Posts: 293
Posted: November 10, 2014 at 10:49 AM / IP Logged
check pink wire on CN2 plug pink wire,This wire will remote start the vehicle when grounded.
it could have been programed to start with option 2-06.
2-06 Timer Start or Interval Between Cold Start - This option dictates the time interval when the control
module will either remote start or check the temperature and remote start.
Default 1: Will start every 3 hours until the vehicle is remote started or started by key and run for 4
minutes.
Option 2: Will start every 1.5 hours until the vehicle is remote started or started by key and run for 4
yyqq
Member - Posts: 6
Posted: November 10, 2014 at 11:22 AM / IP Logged
minutes.
thanks again. but I did not used the pink wire. I taped all unused wire and tied together. I used all default setting except 2-10. I will check if it touch somewhere.
