blade bypass
newbieve6
Member - Posts: 42
Posted: December 05, 2014 at 12:52 PM / IP Logged Link to Post Post Reply Quote newbieve6
Hi,
Compustar calls COM-Blade-AL, Omega calls OL-Blade-AL, etc.
Are these same as ADS-Blade-AL or anything different between
them. Like if I plug in ADS-Blade-AL into a Omega or Compustar
brains what will happen?
Platinum - Posts: 7,789
Posted: December 05, 2014 at 2:00 PM / IP Logged Link to Post Post Reply Quote kreg357
Just plugged a Omega OL-Blade-AL into a Compustar CM6200-s controller.  It is detected and can be flashed at the iDatalink WEB site.  Don't have any Omega EDPB units to test the reverse.
Standard warning re : the Blade modules memory size...  There are 32k, 64k, etc, modules.
newbieve6
Member - Posts: 42
Posted: December 05, 2014 at 3:23 PM / IP Logged Link to Post Post Reply Quote newbieve6
Hi,
Thank you so much for answering for my two posts.
tedmond
Gold - Posts: 4,610
Posted: December 05, 2014 at 3:47 PM / IP Logged Link to Post Post Reply Quote tedmond
ADS-BLADE-AL/COM-BLADE-AL
OL-BLADE-AL
depending on region, they sometimes lock the module for regional purposes. if the region lock doesn't apply you'll be fine. SImple breakdown.
ADS-BLADE-AL/COM-BLADE-AL/OL-BLADE-AL - identical in terms of features/flash.
OL-BLADE-AL in compustar brain, you wont be able to update the brains software. however it can be done separately.
with a compustar if you use the correct cartridge, you can modify the brain software/config right from www.compustar.idatalink.com
Ted
Compustar Expert
newbieve6
Member - Posts: 42
Posted: October 25, 2015 at 11:03 AM / IP Logged Link to Post Post Reply Quote newbieve6
Thanks. One more question, about 32 bit and 64 bit blades, are they functionally same? Or have to use one or the other depending on application?
Posted: October 25, 2015 at 7:38 PM / IP Logged Link to Post Post Reply Quote kreg357
Some of the newer firmwares require the larger 64K Blade modules.  The WEB site doesn't specifically point this out, it just doesn't list any firmware that won't fit onto the 32K Blade cartridge you have plugged in when you select the vehicle. Same thing happens with older 32k ADS AL-CA modules.  If you are obtaining these modules from a normal distribution source, there will be no problems.  If you get them as "old stock" or off EBay, buyer beware.
Wednesday, May 29, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
