Auto page door lock reversed when running
mcculleb
Member - Posts: 6
Posted: December 20, 2015 at 12:00 PM / IP Logged Link to Post Post Reply Quote mcculleb
Hello
Just installed an Autopage RS-730A with an Idatalink ads-alca module into a 2011 Honda CRV.
Everything is working correctly exempt for when I remote start it. After starting, the door unlocks and stays unlocked. The remote still shows it as locked. When I hit unlock, the doors lock and the remote shows lock. When I hit lock, they unlock and the remote shows locked. After shutting down the vehicle, proper operation resumes. Is there a setting that I am missing to fix this?
Thank you.
Brian McCullen
dairyboy3
Copper - Posts: 52
Posted: December 20, 2015 at 12:20 PM / IP Logged Link to Post Post Reply Quote dairyboy3
Sounds like the module is disarming the factory alarm upon remote start and not re arming after it starts. You can change that in the module settings on the computer if you are using the ads-alca for transponder bypass and door locks.
mcculleb
Member - Posts: 6
Posted: December 20, 2015 at 12:29 PM / IP Logged Link to Post Post Reply Quote mcculleb
Thank you! I will look into this tonight and get back with the results.
Brian McCullen
Friday, May 31, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
