Sirens going bad?
reelizmpro
Member - Posts: 14
Posted: December 29, 2016 at 2:46 PM / IP Logged Link to Post Post Reply Quote reelizmpro
I installed an Omega K9 160LA under a year ago. Sensitivity was too high so I had several false alarms. Until one day, the siren stopped working altogether. I bought a DEI 514LN and replaced the siren. The new siren worked although it didn't sound normal. It was omitting a high pitch squeal before it too died a few moments later. Applying 12v to either siren does nothing. The wiring measures 12v, ground is good and the battery was charged. I'm worried if I get another siren that it too will fail. Any thoughts?
Platinum - Posts: 13,677
Posted: December 30, 2016 at 12:20 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Do you have it mounted directly above the exhaust manifold?
Is it mounted with the opening facing downward?
Custom_Jim
Copper - Posts: 210
Posted: December 30, 2016 at 1:30 PM / IP Logged Link to Post Post Reply Quote Custom_Jim
Like i am an idiot stated, make sure it's mounted properly and away from heat but sometimes you never know and maybe you got some back to back defective sirens. I've had goofy things happen like that through 30+ years of installing and I then start second guessing things only to find out nothing was wrong with the install at all but it was just an unlucky roll of the dice and the parts.
Jim
1968 Chevy II Nova Garage Find 2012
1973 Nova Custom
1974 Spirit of America Nova
1973 Nova Pro-Street
reelizmpro
Member - Posts: 14
Posted: December 31, 2016 at 4:49 PM / IP Logged Link to Post Post Reply Quote reelizmpro
The siren is on the intake side fender securely mounted downward facing the front. It is clean and dry using a chassis ground bolt nearby. I contacted Omega who said they would replace it under warranty. I'll probably send it back to see what they come up with. I didn't seen anything fried inside either siren. Everything looks normal, they just don't work anymore.
Saturday, June 8, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
