Viper 4706V w/dball2 in Mazda 2 2011
waldbloc4
Member - Posts: 11
Posted: January 01, 2017 at 9:58 AM / IP Logged Link to Post Post Reply Quote waldbloc4
unable to program dball2 not sure if i'm missing anything.
this list has the ones i connected.
DBALL2:
Red harness:
H9: violet/brown (door lock output mux)--powerlock pink in mazda2
H10: yellow/black ( Data Tx)            -- green in mazda2
H11: ORANGE / black (Data Rx)             -- grey in mazda2
Blue Harness:
H3: tan/black: HS CAN High pin6
H4: tan      : HS CAN Low pin14
Black harness:
H9: + ignition input
D2D to viper
ON the VIPER 4706v:
Heavy gauge relay wire 8 pin harness:
#1 RED / blck to 12(+) --red
#2 pink/blck        --not used
#3 pink/white to ACC2--bla=\ck/white
#4 red to 12(+)      --red
#5 violet to starter --BLACK/ blue
#6 orange to ACC1    --BLACK/ red
#7 RED / white to 12(+)--red
#8 pink to ignition --BLACK / YELLOW
Main Harness 6 pin connector:(this is where i know i need help)
H/1 red 12(+)--red in mazda2
H/2 Black ground(-)
H/3 not used
H/4 not used
H/5 to parking lights(-) BROWN / white w/fuse set to (-) on viper
H/6 not used
Door lock 3 pin connector not used
Auxiliary/shutdown Harness 24 pin:(also unsure)
i only connected
H/13 BLACK/ white to ground(-)
thanks
smokeman1
Platinum - Posts: 1,588
Posted: January 01, 2017 at 4:42 PM / IP Logged Link to Post Post Reply Quote smokeman1
Do you get the solid red light?
waldbloc4
Member - Posts: 11
Posted: January 01, 2017 at 7:46 PM / IP Logged Link to Post Post Reply Quote waldbloc4
yes i do.
i put the first key and then it flashes green,
then within 3 secs i put the 2nd key and it flashes orange.
then i remove the key and within 3 secs i'm supposed to remote start the car whie holding the program button on the dball2.
but my 2 way remote shows me fails to communicate with viper.
and the car never remote start to finish the programming.
i disconnected the dball2 wiring to get the red light.
and tried all over about 4 times still no luck.
thanks
smokeman1
Posted: January 01, 2017 at 9:13 PM / IP Logged Link to Post Post Reply Quote smokeman1
Sounds like the remote needs to be paired to the brain.
I would go through the pairing procedure.
waldbloc4
Member - Posts: 11
Posted: January 02, 2017 at 10:55 AM / IP Logged Link to Post Post Reply Quote waldbloc4
the pairing procedure talks about a control center button. i don't what that is.
smokeman1
Posted: January 02, 2017 at 11:10 AM / IP Logged Link to Post Post Reply Quote smokeman1
That would be the button on the antenna, called the control center.
waldbloc4
Member - Posts: 11
Posted: January 02, 2017 at 11:27 AM / IP Logged Link to Post Post Reply Quote waldbloc4
thanks to you. i'm making progress.
i was able to pair it now.
and the remote responds with lock and unlock functions with parking lights flashing but doors don't lock or unlock.
but now i get error code instead on the last step of programming the dball2. first and second step is good but the third step while i'm supposed to hold the dball2 button and press remote start that's where it fails it displays an error on lcd remote.
smokeman1
Posted: January 02, 2017 at 12:15 PM / IP Logged Link to Post Post Reply Quote smokeman1
Just above step 2 on page 7, it states to make sure all door are closed before executing the programing sequence.
Are all door closed?
waldbloc4
Member - Posts: 11
Posted: January 02, 2017 at 1:00 PM / IP Logged Link to Post Post Reply Quote waldbloc4
yes i tried with all doors closed.with no luck.
also in order to get the solid red light back i diconnect all wiring from dball2 and plug the black then red then blue connector and press and hold the dball2 button and plug the white D2D and release button.
when i bought the dball2. according the ebay seller he said he flashed it for mazda2.
also is the programming necessary to unlock and lock doors, since now i only see the lights flashing on mazda2 but locks don't respond.
waldbloc4
Member - Posts: 11
Posted: January 02, 2017 at 1:44 PM / IP Logged Link to Post Post Reply Quote waldbloc4
on that 3rd step the the car lights flashes about 7 times.
saw somewhere online that it's possible that viper is on manual mode
Saturday, June 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
