2004 Tibouron Door locks
sparxx513
Copper - Posts: 56
Posted: January 22, 2017 at 3:28 PM / IP Logged Link to Post Post Reply Quote sparxx513
Anyone have a good diagram or can explain how the type F door lock works? According to the diagram its says one wire will test with drivers door, the other will test with passenger door. Do i need to use both and diode isolate? Will be using a viper 350Plus.
Thanks in advance
sparxx513
Copper - Posts: 56
Posted: January 25, 2017 at 3:19 PM / IP Logged Link to Post Post Reply Quote sparxx513
anyone?
wirewise
Moderator - Posts: 489
Posted: January 25, 2017 at 3:37 PM / IP Logged Link to Post Post Reply Quote wirewise
You only need to use one wire to lock and unlock. Here are two diagrams. https://www.the12volt.com/doorlocks/page2.asp#n1 One uses a relay and a diode, the other uses 2 relays.
~wirewise~ Verify all wiring with your meter before making any connections!
lectricguy
Copper - Posts: 359
Posted: January 26, 2017 at 5:31 AM / IP Logged Link to Post Post Reply Quote lectricguy
Here you go:
http://static.voxxintl.com/docs/tech/11/2003_Hyundai_Tiburon_Door_Locks.pdf
Lectric Guy
