Compustar Model ID?
monty_77
Copper - Posts: 491
Posted: February 12, 2018 at 8:10 AM / IP Logged Link to Post Post Reply Quote monty_77
Compustar Model ID? -- posted image.Compustar Model ID? -- posted image.Compustar Model ID? -- posted image.
I know it compustar was wondering on model, have not gotten it in yet, had customer send pics to help I’d so I could find manuals
Any help is appreciated
Platinum - Posts: 7,790
Posted: February 12, 2018 at 7:22 PM / IP Logged Link to Post Post Reply Quote kreg357
The remotes are probably 1W900FMR's. Decent remotes with 3,000 foot range.
They can be paired with almost any Compustar system, from the CM3000 to the latest models.
You really need to see the remote start controller box to know what you have.
monty_77
Copper - Posts: 491
Posted: February 12, 2018 at 7:33 PM / IP Logged Link to Post Post Reply Quote monty_77
Ok Thank you , will just have to wait until customer gets it to me
doorlocks are working, but will not start, and the parklights are not hooked you for error codes
had him look for an on off switch under dash driver side, but not sure he had an idea what to do!
Posted: February 12, 2018 at 7:40 PM / IP Logged Link to Post Post Reply Quote kreg357
It might just be in Valet Mode, especially if the Parking Lights are not responding to lock commands
and everything used to work. I would try exiting Valet Mode before getting serious. Here is the info :
Q: The vehicle will lock and unlock, but will not remote start or flash the parking lights.
A: The system is in Valet Mode. Tap the Lock and Trunk Buttons at the same time for a half second to
    exit Valet Mode. If that does not work try reprogramming the remotes again.
monty_77
Copper - Posts: 491
Posted: February 12, 2018 at 8:16 PM / IP Logged Link to Post Post Reply Quote monty_77
ok thanks will try to reprogram remotes after i try and get it out of valet mode not confident in the customer is doing it right
Thanks for the help
Monday, June 3, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
